Accessory Switch Replacement
Bc55
Postby Bc55 » Wed Jan 23, 2019 5:41 pm
[This thread has been moved to SMALL BOAT ELECTRICAL for discussion--jimh]
Hello all. I own a 2010 Montauk 150. I want to add a horn on the side of the console. The console has one accessory rocker switch that I’d like to utilize for the horn. The [unused] switch now is ON-OFF but stays in [the] ON-position I’d like to put a toggle switch so it can’t stay in the ON position.
What switch will be a rocker-switch and toggle-switch that can be a horn switch that will be a direct replacement [for the existing switch]?
Thanks--B
Re: Accessory Switch Replacement
Postby Phil T » Wed Jan 23, 2019 8:21 pm
Look at your switch and review the many many variations of the "water resistant Contura switch.
Blue Seas, Sea Dog and others all make them.
You are look for an off-momentary on switch.
https://www.amazon.com/Rocker-Switch-Contura-Carling-Hersee/dp/B01FYC8XSO/ref=sr_1_7?s=boating-water-sports&ie=UTF8&qid=1548292811&sr=1-7&keywords=contura+horn+switch
[IMPORTANT--the above link is just for a switch snap-on actuator or cover. It is not for an entire switch assembly with the desired OFF-ON(momentary) action.--jimh]
Postby jimh » Wed Jan 23, 2019 9:49 pm
BC55--You are confused about switch nomenclature. A "toggle" switch does not mean the switch has a momentary action. Generally the term "toggle switch" refers to the type of actuator used on the switch. A toggle switch typically has a bat handle actuator.
The term rocker-switch generally refers, again, to the type of actuator. A rocker switch typically does not have a bat-handle or toggle actuator, but has an actuator that rocks back and forth, like a see-saw, between two positions, or in some instances three-positions, with a center or balanced position.
Since you have a Boston Whaler boat of recent vintage, the switch on your helm panel is very like a CARLING CONTURA-series marine switch.
Among all electrical components, switches can be some of the most complicated to order. There are often a dozen parameters of the switch that must be specified. Inasmuch as I infer you are not an expert in CONTURA switches, you probably won't be able to specify the precise switch you want as an OEM part from the switch manufacturer. To make the switch a drop-in and simple replacement, you would have to get the proper switch series, get the proper switch electrical configuration, get the proper switch action, get the rocker engraved with the proper legend, and get the proper terminals on the back of the switch, get the colors correct, get the illumination option correct, and get the lens color correct. This can be very complicated to specify, and then very expensive and time consuming to order.
The simplest solution for you is to get the switch from a Boston Whaler dealer or to find an off-the-shelf switch that will fit. CONTURA-series switches are very common in boat electrical panels. A switch with an action of OFF-ON(momentary) with a HORN legend should also be common. If your present switch color is black, that is the most common. If the switch is not illuminated, again, very common
Disconnect the wiring to the switch (you want to replace) and remove the switch from the panel. Take the original switch with you to a good marine supplier, and ask for an equivalent switch with the switch action OFF-ON(momtary) and with a HORN legend on the actuator.
Postby jimh » Wed Jan 23, 2019 10:31 pm
Here is a BLUE SEA SYSTEMS part number for a CONTURA II Black, non-illuminated switch with action OFF-ON(momentary)
https://www.bluesea.com/products/7930/C ... F-%5BON%5D
I don't know if the terminals on this switch will match the ones on your Boston Whaler. You can see the terminals in an illustration on the page linked above.
Postby jimh » Wed Jan 23, 2019 10:40 pm
The vendor linked below may stock CONTURA switches with actuator covers with common legends (such as HORN):
New Wre Marine
https://newwiremarine.com/marine-grade-switches/contura-ii/
I like their switch for HORN because it has a distinctive red cover, making it easy to find on the panel:
HORN Switch
https://newwiremarine.com/product/red-horn-rocker-switch-contura-ii/
Note they are offering both the switch and the engraved cover for a very modest price--and they use genuine CARLING switches, not made-in-China fakes.
Bc55
Postby Bc55 » Thu Jan 24, 2019 8:15 am
Thank you for all the replies. I guess my first step is to pull out the accessory switch and take it to the local marine shop to see if they have a matching switch off-on(momentary).
I do like the red cover for the horn switch. I will have to look into that.
Thanks.
Postby jimh » Mon Jan 28, 2019 10:34 am
Most important: before you disassemble the wiring to the switch in the console at present, take a good digital image of the switch and wiring, make a sketch of the wiring, and mark all wires with temporary labels. This will allow you to re-connect the new (or old) switch without having to deduce the wiring from a jumble of disconnected wires.
