Outboard for 15-footer
Caseycjones
Postby Caseycjones » Wed Mar 20, 2019 9:44 pm
I may buy a Yamaha 75c. Is this engine good for a 1976 15-footer?
The [peak cylinder pressure reading] on all cylinders is 100-PSI; is that a problem?
Down the road will [these pressure readings be a] problem?
Re: Outboard for 15-footer
Postby jimh » Wed Mar 20, 2019 10:23 pm
For advice on how to evaluate readings of cylinder pressure see
Assessing Used Outboard Engines
http://continuouswave.com/whaler/refere ... Check.html
I don’t know how to predict future problems that could occur with the engine under discussion based on the information you provided.
Read more about the Yamaha 75c model at
https://global.yamaha-motor.com/busines ... index.html
dgoodhue
Postby dgoodhue » Mon Mar 25, 2019 9:16 pm
My biggest concern [in selecting an outboard engine for a 15-foot Boston Whaler] is engine weight. [Some engine only identified as a] current four-stroke-power-cycle engine weighs 353-lbs, which is more weight than I would want on a classic 15-footer.
TFrere
Postby TFrere » Mon Mar 25, 2019 11:35 pm
If worried about the weight, consider the Yamaha F70 which is 253-lbs. An increase of 100-lbs is a lot for only an additional 5-HP.
1985 15’ Sport with Yamaha F70
Postby jimh » Tue Mar 26, 2019 12:57 am
Caseycjones wrote:I may buy a Yamaha 75c.
Are you trying to refer to a Yamaha F75C?
Or to the classic two-stroke-power-cycle engine the 75c that weighs about 265-lbs?
Unless you clearly identify the engine, readers can only guess which engine you are asking for advice about.
