1991 Outrage 17 Navigation Lamp Replacement Parts
jhpeterson3
Postby jhpeterson3 » Mon Apr 08, 2019 9:59 pm
I have the original [combined sidelight navigation lamp] on my [1991] Outrage 17. The lamp housing is in great shape. The electrical wiring is good. The inside and the [light bulb socket] have failed.
[Can the inside and the light bulb socket] be replaced? Many thanks.
Re: 1991 Outrage 17 Navigation Lamp Replacement Parts
Postby jimh » Mon Apr 08, 2019 11:14 pm
I suspect that "the inside" means the red and green lens.
Contact a knowledgeable Boston Whaler dealer parts department to inquire if the red-green lens and the light bulb socket from the combined sidelight lamp fixture for your 1991 Boston OUTRAGE 17 can be purchased as repair parts.
Postby jimh » Mon Apr 08, 2019 11:18 pm
The lightbulb socket is probably a standard bayonet mount miniature light bulb socket, and you can often find these as replacement parts from many vendors, not just from a Boston Whaler dealer.
If "the inside" means the red-green lens, you may be able to restore the lens. Some plastics tend to become hazy and foggy over time. These plastics can be restored by careful cleaning and polishing. Automotive stores often sell plastic polishing compounds.
jhpeterson3
Postby jhpeterson3 » Tue Apr 09, 2019 10:26 am
Thank you. The lenses are both in good shape. The part that is broken is the light [bulb socket] assembly that is connected to the wiring. Many thanks.
Postby Phil T » Tue Apr 09, 2019 4:36 pm
John -
Can you shoot a photo of yours light base? I don't think the one Archie linked to is accurate.
If not, I could disassemble mine and take one.
Let me know. :-)
