INSTANCE Settings for FLUID TANKS in E-TEC G2 Rigging
Postby jimh » Sat Apr 13, 2019 3:39 pm
In the Evinrude E-TEC G2 engine rigging, there is a convention or standard used for the INSTANCE parameter associated with fluid tank level senders. A list of INSTANCE value and the reserved function with E-TEC G2 rigging and instrumentation follows. (I use A-B-C-D to identify the analog inputs in order to avoid confusion with multiple numerical identifiers; the actual labels on the wiring are likely to be different):
INSTANCE ---> Reserved function
0 = E-TEC G2 engine under-cowling OIL reservoir tank level, single engine or port engine in multi engine
1 = E-TEC G2 under-cowling OIL reservoir tank level, starboard engine in twin rigging, center in triple rigging, port-center in four-engine rigging
2 = E-TEC G2 under-cowling OIL reservoir tank level, starboard engine in triple rigging, starboard-center in four-engine rigging
3 = E-TEC G2 under-cowling OIL reservoir tank level, starboard engine in four-engine rigging
4 = reserved for the first input (A) of the four analog inputs (A-B-C-D) on the ICON II EST control head
5 = reserved for the second input (B) of the four analog inputs (A-B-C-D) on the ICON II EST control head
6 = reserved for the third input (C) of the four analog inputs (A-B-C-D) on the ICON II EST control head
7 = reserved for the fourth input (D) of the four analog inputs (A-B-C-D) on the ICON II EST control head
8 = reserved for the single analog input of the ICON 4.3 CTS display or the first input (A) of the three (A-B-C) inputs of the ICON 7 CTS display
9 = reserved for the second input (B) of the three (A-B-C) analog inputs of the ICON 7 CTS display
10 = reserved for the third input (C) of the three (A-B-C) analog inputs of the ICON 7 CTS display
11 thru 15 = reserved for NMEA-2000 tank level convertor devices separate from any engine or display analog inputs.
In the case of INSTANCE 0 to 3, the E-TEC engine sends these according to how the engine EMM INSTANCE has been programmed. The E-TEC engine will be sending the under-cowling oil tank reservoir level for the engine, using INSTANCE 0,1,2, or 3 as appropriate to the total number of engines and the position of the engine in multi-engine rigs.
In general, none of the INSTANCE settings of the analog input converters on the Evinrude display or control devices can be changed.
TANK TYPE ---> Preset configuration
The TANK TYPE is a separate parameter from INSTANCE. In the Evinrude system the following TANK TYPES are pre-set:
INSTANCE 0,1,2,and 3 are set to be TANK TYPE = OIL in the EMM of the E-TEC G2; these cannot be changed.
INSTANCES 4,5 are preset to be TANK TYPE = FUEL. These can be modified to be OIL. See below.
INSTANCES 6,7 are preset to TANK TYPE = OIL, These can be modified to be FUEL. See below.
INSTANCE 8,9,10 are preset to be TANK TYPE = OIL. These can be modified to be FRESH WATER, GRAY WATER, or BLACK WATER.
EVINRUDE CONTROLS or DISPLAYS and ANALOG INPUTS
The Evinrude ICON II PREMIUM EST controls typically provide four analog inputs (A-B-C-D) that are intended for connection to resistive fluid tank level senders. These inputs are pre-configured as INSTANCE 4-5-6-7. The TANK TYPE parameter is pre-set to FUEL as TANK 1 and TANK 2 corresponding to INSTANCE 4-5 and to OIL 1 and OIL 2 corresponding to INSTANCE 6-7. NOTE: IT IS NOT POSSIBLE TO ALTER THE INSTANCE SETTINGS FOR THESE INPUTS. The TYPE setting can be changed. See below.
The Evinrude ICON II (BASIC) EST controls do not provide analog inputs for connection to resistive fluid tank level senders.
The Evinrude ICON 4.3 Color Touch Screen (CTS) Display has one analog input intended for connection to a resistive fluid tank level sender. This input is INSTANCE = 8 and cannot be changed. The TYPE can be configured (using the display itself) to be set to TYPE = OIL, FRESH WATER, GRAY WATER, or BLACK WATER.
The ICON 7.0 Color Touch Screen (CTS) display has three analog inputs that can be used with resistive senders from fluid tanks. These inputs are pre-configured to be TYPE = OIL (and designated OIL 1, OIL 2, OIL 3 corresponding to INSTANCE 8,9,10 ). The TYPE can be configured (using the display itself) to be set to TYPE = OIL, FRESH WATER, GRAY WATER, or BLACK WATER. See below.
The ICON 3.5 C color display has no analog inputs.
The NAUTILUS display (sometime referred to as the Evinrude ICON II 3.5 Round display) has no analog inputs
Note: if external fluid tank level sensors with NMEA-2000 output are used to monitor tank levels, those NMEA-2000 devices will have to be pre-configured to have the proper INSTANCE and tank TYPE in order to be useful with displays such as the Evinrude ICON CTS and CS display which are preset to look only for certain INSTANCE settings. In some situations EV-Diagnostics Version 6 can perform those configurations. The ICON CTS or CS gauges cannot configure the INSTANCE settings of NMEA-2000 senders (as far as I can tell), but they can configure the TYPE setting.
EVINRUDE CONTROLS and DISPLAYS: CONFIGURATION ABILITY
The four analog inputs for the ICON II PREMIUM EST controls can be configured by EV-Diagnostic Version 6, by an ICON 7.0 CTS display, or by an ICON 4.3 CTS display to change the TANK TYPE to be either FUEL or OIL.
The analog inputs on the ICON 7.0 CTS and the ICON 4.3 CTS can be configured by the displays themselves to set the TANK TYPE for each analog input. The TANK TYPE can be set to OIL, FRESH WATER, GRAY WATER, or BLACK WATER.
Re: INSTANCE Settings for FLUID TANKS in E-TEC G2 Rigging
Postby jimh » Wed Apr 17, 2019 12:02 pm
Below is a excerpt from the 2016 Evinrude rigging guide for G2 engines, page 18, that presents the information about INSTANCE reservations that is described in the narrative above:
Reserved Fluid Level Instancing
When installing and setting up fluid level devices on the NMEA 2000 network, the following instance numbers are reserved and should not be used for any other devices.
Table 1. NMEA-2000 INSTANCE Reservations for Fluid Tank Level Senders. See caption below for help in interpretation of this table.
NOTES:
[Where the numbers 1 or 2 appear in the columns for oil, fuel, or other, they are referencing the following foot notes:]
1. ICON II remote controls: Default settings shown. Can be reconfigured to monitor fuel or oil levels.
2. ICON Touch digital displays:Default settings shown. Can be reconfigured to monitor fresh water, gray water, or black water levels.
Postby jimh » Wed Apr 17, 2019 12:21 pm
Note that in the Evinrude system, FUEL tank levels must come from devices with INSTANCE 4-5-6-7. The only Evinrude devices configured with those instances are the ICON II PREMIUM EST remote controls. If a boat is not rigged with those controls, to have display of FUEL tank level on the NMEA-2000 network and on the Evinrude displays, a separate NMEA-2000 convertor device for tank levels must be used. This separate convertor device must have INSTANCE =4 for a single fuel tank level and TYPE set to FUEL.
The easiest path to achieve this may be to buy Evinrude part 768916, which is a NMEA-2000 sender preset as INSTANCE =4 and TYPE = FUEL. See below.
Fig. 1 Evinrude part 0768916, a fuel tank level sender with INSTANCE =4.
A NAVICO Fluid Level Converter (Part 000-11518-01) can also be used, but some method to configure its INSTANCE and TYPE must be available. The EV-Diagnostics Version 6 application can configure the NAVICO convertor, and a NAVICO multi-function display should also be able to configure it.
Postby jimh » Fri May 20, 2022 9:54 pm
Here is some context on the FLUID TANK LEVEL senders and their INSTANCE settings related specifically to the E-TEC G2 and NAUTILUS:
I believe the E-TEC G2 engine all had internal oil tank reservoirs, and those tanks have level senders which connect to the EMM or perhaps directly to the PUBLIC NETWORK (a NMEA-2000 standard network). The FLUID TANK LEVEL data is configured to be sent as TYPE=OIL and INSTANCE = 0, 1, 2, or 3, which allows for up to FOUR E-TEC G2 engine to be connected to the network, and for the level of the internal oil reservoir tank in up to four engines to be available to the NMEA-2000 network.
With INSTANCE settings 0, 1, 2, and 3 allocated to the FLUID TANK LEVEL and TYPE=OIL, the NAUTILUS gauge is pre-configured to look for oil tank level data at those instance setting and type settings. Of course, the NAUTILUS gauge can only be used with two engines, not with four engines, which leaves INSTANCE = 2 or 3 as perhaps "wasted" for use with a NAUTILUS gauge, but this is a necessity to allow for the rare case of four-engine rigging, which will be using a more complex Evinrude display than the lower-tier NAUTILUS display.
Because FLUID TANK LEVEL INSTANCE settings 0 to 3 are already allocated to oil tanks, the NAUTILUS gauge is preconfigured to look for fuel tank levels to come from a FLUID TANK LEVEL TYPE=FUEL and INSTANCE=4 or 5. Note that INSTANCE = 6 or 7 can be also be used for fuel, giving a possibility for four fuel tanks to be used, but not with the NAUTILUS. Again, the more complex EVINRUDE displays would be need for boats with four fuel tanks.
This pre-configuration of the INSTANCE and TYPE settings was part of a general scheme devised by Evinrude for the NMEA-2000 network settings for FLUID TANK LEVEL data. When an E-TEC G2 engine would be rigged using all Evinrude devices and using specific part numbers, everything would be pre-coordinated with regard to TYPE and INSTANCE settings for all FLUID TANKS, both oil tanks and fuel tanks. This pre-configuration would simplify the installation, rigging, and configuration of the instrumentation system for properly trained installers using proper Evinrude parts.
In contrast, with devices made by NAVICO (under their SIMRAD and LOWRANCE brands), there is no particular motivation for NAVICO to pre-configure any of their FLUID TANK LEVEL NMEA-2000 convertor devices to have the particular settings for INSTANCE and TYPE as used by Evinrude. An expectation that NAVICO would pre-configure everything to suit the EVINRUDE scheme is a naive assumption.
In the same manner, if a SIMRAD display is to be used with an E-TEC G2 engine, there is no basis to anticipate or expect or assume that the SIMRAD display will be pre-configured to look for oil tank or fuel tank data coming with the particular INSTANCE and TYpE settings that Evinrude has selected for their engine and their tank level senders. Again, an expectation that NAVICO would pre-configure everything to suit the EVINRUDE scheme is a naive assumption.
If a boater desires that both an Evinrude NAUTILUS display and a SIMRAD display should show oil and fuel tank levels, then the boater must configure the tank level senders to suit the PRE-CONFIGURED values in the NAUTILUS, and then the boater must CONFIGURE the SIMRAD display to match those values.
