How to Post a Draft
Introduction to the forum software and its feature. You can use this for test postings. This is not a boating forum
How to Post a Draft
Postby Jefecinco » Sun Jul 21, 2019 11:20 am
I would like to post a draft - Instructions?
Re: How to Post a Draft
Postby jimh » Sun Jul 21, 2019 9:33 pm
After composing an article, to save as a draft click the button SAVE AS DRAFT which appears as an option below the text entry field.
Postby Jefecinco » Mon Jul 22, 2019 9:12 am
Thank you Jim. I have saved a draft I would like to post to the forum. How is that done?
Postby Phil T » Mon Jul 22, 2019 11:14 am
Butch.
On the upper right of the page is your username with a down triangle. Click to reveal sub menu, select User Control Panel.
On the first tab, (default), select the 4th option, Manage drafts
Postby Jefecinco » Tue Jul 23, 2019 10:12 am
Thanks, Phil. I should have known the "Load Draft" button was what I needed to use. For some reason I wanted to see something like "Post Draft".
Anyway it is now posted in Small Boat Electrical.
