Montauk 17 Railing Stanchion Support Backing Plates
Reelescape1
Postby Reelescape1 » Fri Aug 09, 2019 12:17 pm
Fig. 1 MONTAUK 17 Port View [which may be trying to show no backing plate in place]
Fig. 2. MONTAUK 17 Starboard View [which may be trying to show use of a backing plate]
A Montauk 17 hull [is shown with a hidden railing] stanchion and a [visible exterior of hull backing plate].
[On the boat under discussion on the Starboard side the] lower-mount-top-support exterior is through-bolted .
[On the boat under discussion on the Port side there is something that] appears [to be different].
Is this the original design for c.1988?
Re: 17' Montauk bow rail question
Postby Phil T » Fri Aug 09, 2019 1:28 pm
The starboard side is original.
The only source for replacements that I am aware of is http://www.specialtymarine.com/BOSTON-WHALER-STAND-OFF-STANCHION-BACKING-PLATE-p153.html
I doubt they will match OEM so you may want to replace both and keep the original just in case.
Re: Montauk 17 Railing Stanchion Support Backing Plates
Postby jimh » Fri Aug 09, 2019 3:13 pm
PHIL--without your reply I would not have understood the initial question. Thanks for interpretation.
Reelescape1
Postby Reelescape1 » Fri Aug 09, 2019 7:43 pm
PHIL--Thank you. [A replacement backing plate for a MONTAUK 17 railing stanchion support was] exactly what I was after.
