1994 Outrage 21 Steering Leak
nwwhalerguy
Postby nwwhalerguy » Tue Sep 10, 2019 12:04 pm
I bought a well-preserved 1994 Outrage 21 with what I believe to be a Teleflex steering system, the kind with the adjustable tilt helm. The hydraulic system at the helm has started to leak and I am researching replacement gaskets or O-rings for that part of the system. There are no identifying serial or model number on the helm, just a Teleflex label.
Give me input regarding the model of system that was shipped with that model year OUTRAGE.
Guide me to a parts distributor.
The advice will be greatly appreciated. Thanks
Re: 1994 Outrage 21 Steering Leak
Postby jimh » Wed Sep 11, 2019 8:44 am
Here is some advice:
Teleflex Helm Pump Seal Replacement
http://continuouswave.com/whaler/reference/teleflexSeal.html
A leak at the input shaft at the helm is a very common problem and is easily remedied.
conch
Postby conch » Wed Sep 11, 2019 12:50 pm
My 1996 Seastar Pro tilt helm is model HH5774 2.0 cu.in. You did not say where yours is leaking. Rebuild kits for the helm [being sold on] Amazon are around $40.
If just the shaft seal is leaking I have both dash-210 & dash-214 (3/4 & 1in quad rings) I can mail to you. Let me know.
I also have 2 Yamaha covers for 1990s V6 outboards, great to keep off the sun and weather from your engine hood.
Chuck
nwwhalerguy
Postby nwwhalerguy » Thu Sep 12, 2019 11:33 am
Thank you both for the help here. I researched the helm at the time of original sale from Boston Whaler technical support and it is a Seastar/Teleflex type HH-6541-3. The replacement seal kit is number 6032 available from Seastar Solutions. Chuck I will take you up on your offer of the quad O ring for the 3/4" diameter shaft seal, as it appears to be the only seal on the helm pump according to the Seastar diagram of the pump. Cheers!
conch
Postby conch » Thu Sep 12, 2019 1:26 pm
Seal 3/4in. is in the mail from Islamorada.
Chuck
