For single engine installation, the E-TEC EMM should be set to INSTANCE 00. This is the standard setting for an E-TEC engine as delivered from the factory: EMM INSTANCE 00.
To change the E-TEC EMM INSTANCE, there are two methods. The most common method is to use EV-DIAGNOSTICS software, connect to the EMM, and change the EMM INSTANCE setting. In certain configurations of legacy E-TEC engines which have been fitted with the legacy ICON EST controls, the EMM INSTANCE setting is over-ridden by a hardware setting in the ESM module, and this setting is configured by insertion of a special ID plug into a socket on the ESM module. But other than that case, engine EMM is set by software.
To set the EMM by software, the EV-DIAGNOSTICS software must be used. In general, EV-DIAGNOSTICS software is available to all dealers. In addition to the software, you must have an appropriate terminal to execute the software (and typically any WindowsOS computer will do this), have an RS-232 serial port (and typically this is done with a USB-to-RS232 serial port adaptor), and have a specialized RS-232 to EMM Diagnostic Port cable. Further, in addition to all the hardware necessary, some skill in using the software will be needed.
The normal and expected configuration of engine instance for a single engine is INSTANCE 00. For multiple engine configurations, the engine INSTANCE setting begins at INSTANCE 00 for the port engine, and increases by one for each additional engine in the direction toward starboard. To be explicit:
Config. Instance
1-ENGINE: Center = 00
2-ENGINE: Port = 00; Starboard = 01
3-ENGINE: Port = 00; Center = 01; Starboard = 02
4-ENGINE: Port = 00; Port-center = 01; Starboard-center = 02; Starboard = 03
5-ENGINE: Port = 00; Port-center = 01; Center = 02;
Starboard-center = 03; Starboard = 04Engines intended to be used in multiple-engine rigging will need to have their EMM INSTANCE settings changed from the default INSTANCE 00 setting. If on a NMEA-2000 network more than one E-TEC engine has the same INSTANCE setting in its EMM, there will be unusual behavior of network devices that are trying to read data from the engines.
