Evinrude Model Codes
Postby jimh » Mon May 04, 2020 9:15 am
Boston Whaler boats, prior to the change to mandatory tie-in sales with Mercury engines following change in ownership to the Brunswick corporation, were often powered by Evinrude engines. Evinrude engines remain a popular choice for re-powering Boston Whaler boats. To help identify Evinrude engine models from their Evinrude model codes, see a new article in REFERENCE
EVINRUDE MODEL CODES
http://continuouswave.com/whaler/reference/evinrudeModelCodes.html
Re: Evinrude Model Codes
Postby biggiefl » Mon May 04, 2020 10:37 am
The codes are for 1980 model years to present. Pre-1980 uses a different system which is fine if you look it up but not necessarily the easiest to decipher just by looking at it. Below is a list of model codes for an OMC 25hp. As you can clearly see the #9 in the model number shows that it is a 1969. Look at the 1979 model and it is almost identical so some could guess the wrong decade just by looking at the model number.
1969 25902
25903
1970 25002
25003
1971 25102
25103
1972 25202
25203
25252
25253
1973 25302
25303
25352
25353
1974 25402
25403
25452
25453
1975 25502
25503
25552
25553
1976 25602
25603
25652
25653
1977 25702
25703
25752
25753
1978 25802
25803
25852
25853
1979 25904
25905
25952
25953
