16 SL Hull Drains
dawnfred
16 SL Hull Drains
Postby dawnfred » Wed May 13, 2020 2:58 pm
[This article was posted to an existing thread on a completely different and totally unrelated topic. Don’t revive old threads and change the topic. Start a new topic. Use the NEW TOPIC button. The NEW TOPIC button appears in the listing of thread topics—jimh.]
What [hull] drains [should be] plugged [on a] 16 SL?
Re: 16 SL Hull Drains
Postby jimh » Fri May 29, 2020 9:20 pm
Read the owner’s manual for advice on hull drains.
If you do not have a printed copy, go to the REFERENCE section. There you will find an on-line version I created.
REFERENCE SECTION
http://continuouswave.com/whaler/reference/
OWNER’S MANUAL 9 to 17-Foot Hulls
http://continuouswave.com/whaler/reference/manual9-17/
The use of plugs in hull drains depends on where the boat is located and how the boat is being used.
Postby biggiefl » Mon Jun 01, 2020 10:02 am
"The use of plugs in hull drains depends on where the boat is located and how the boat is being used."
Yup!
Postby Phil T » Mon Jun 01, 2020 10:28 am
All the drains except the splashwell.
The plugs are inserted to the tube on the inside of the boat. (it needs to be said, trust me.)
