Circular Clear Pry-out Deck Access Plate
jay18
Postby jay18 » Sat Jun 20, 2020 4:48 pm
Is the [clear, circular pry-out] deck plate for the fuel [tank level gauge] on my [1992–always use for digits for year] Outrage [always specify the length of a particular boat] 7-inch [always specify the dimension being cited]?
[Seeks a source for a replacement].
Re: Circular Clear Pry-out Deck Access Plate
Postby jimh » Sat Jun 20, 2020 5:39 pm
The OEM vendor of the circular pry-out deck access plates on classic era Boston Whaler boats is Beckson, of Bridgeport, Connecticut, in the Eastern Time Zone.
Read this prior article on the topic:
Replacement Deck Pry-out Access Plates
viewtopic.php?f=6&t=2406#p13717
You probably are trying to replace the clear circular pry-out deck plate on your unspecified Boston Whaler boat. The most likely candidate is the 7-1/2-inch-OD clear circular pry-out deck access plate from BECKSON in the color KHAKI. See
https://www.becksondirect.com/product/dp61tk-c/
Information on how to contact BECKSON is found at
https://beckson.com/contact.html
I ordered some replacement circular deck pry-out access plates from them, and they were very easy to work with.
This same information is also provided in the REFERENCE section article on OEM and RECOMMENDED VENDORS. See
http://continuouswave.com/whaler/refere ... tml#pryout
jay18
Postby jay18 » Sun Jun 21, 2020 12:57 pm
Thank you! I will do a better job on the description next time!
