Montauk Teak Bilge Cover Source
Retriever
Postby Retriever » Wed Jul 08, 2020 5:14 pm
Where can the 8 x 9-inch teak cover for aft cockpit sump on a 1986 Montauk 17 boat be purchased?
Thanks
Re: Montauk Teak Bilge Cover
Postby Phil T » Wed Jul 08, 2020 5:18 pm
Contact Bob Latourelle, professional woodworker at (978) 837-8808‬.
He fabricates OEM quality replacement wood parts for Boston Whaler.
Don McIntyre - MI
Postby Don McIntyre - MI » Wed Jul 08, 2020 6:10 pm
And to minimize the need for another one, coat it with a couple of coats of epoxy (without any additives, just straight), especially along the edges and the lift hole. Then a few coats of varnish. It will last much longer.
Regards - Don
Postby biggiefl » Thu Jul 09, 2020 10:12 am
Cut a piece of starboard.
Re: Montauk Teak Bilge Cover Source
Postby jimh » Sat Jul 11, 2020 2:25 pm
Use the old cover as a pattern to cut a new one from mahogany veneer plywood. Coat with epoxy then varnish.
Install a short bungee cord to retain the cover in place using a pad eye on the underside and a pad eye on the boat cockpit bottom in the sump.
frontier
Postby frontier » Sat Jul 11, 2020 2:33 pm
I've used a piece cut out of a WalMart cutting board. Looked and worked great.
Postby jimh » Tue Jul 14, 2020 7:39 pm
frontier wrote:I've used a piece cut out of a WalMart cutting board. Looked and worked great.
Good idea. The term “KING Starboard” means expensive Walmart cutting board.
Postby biggiefl » Tue Jul 14, 2020 8:02 pm
Yup....hence my post above.
dtmackey
Postby dtmackey » Tue Jul 21, 2020 10:26 pm
I've found that I need to remove the bilge cover to access my plug, so I used a scotch plastic (Velcro like) material that uses little balls and sockets to secure it and it's still easy to remove.
https://www.scotchbrand.com/3M/en_CA/scotch-brand-ca/all-products/products/~/Scotch-Extreme-Fasteners-RFD7020-clear-1-in-2-54-cm-/?N=4335+8709316+8709342+8710660+8711017+8711729+3290863752&preselect=3293786499+3294529206&rt=rud
