1989 Outrage Water In Hull
mgl
Postby mgl » Mon Aug 17, 2020 8:25 pm
I just purchased a 1989 Outrage that is in average shape.
On August 15 or 16, 2020, I took out the boats for a brief ride. I forgot to remove the rear drain plug in the sump on the starboard side of the deck—not the splash well— after loading the boat. 0n the trailer.
On August 17, 2020, a day or two loafer, I noticed 4-inches of water in the sump. [There had been] no rain.
Could water from the hull find its way into this sump?
The sump pump did not turn on because the battery switch was off.
Re: 1989 Outrage - hull water
Postby biggiefl » Tue Aug 18, 2020 10:08 am
There is some water in the rigging tunnel and possibly the tank cavity. It is common. Your pump should come on as the pump should be hard wired even if batteries are off. That is not how they did it back then, mine is on a switch.
mgl
Postby mgl » Tue Aug 18, 2020 2:20 pm
Thanks for the input.
I'll keep an eye on [water appearing in the sump when the boat is out of the water].
I will also check the pump [wiring to the battery].
I am sure my [observation] is consistent with your response.
I am still learning—first boat.
Re: Still Learning
Postby jimh » Tue Aug 18, 2020 2:40 pm
I started boating at age eight; soon I will be 70-years old.
I learn something new every time I go boating.
When asking for advice give the year, model, and length of the boat. An “Outrage” could be 17 to 27 feet long.
mgl
Re: 1989 Outrage 18 Water In Hull
Postby mgl » Tue Aug 18, 2020 4:18 pm
You got it. The boat in question is an '89 Outrage 18. Looking forward to learning from the community and hopefully contributing to it at some point.
Thanks to both of you.
