DSC Radio With Internal GNSS Receiver
tyno22
Postby tyno22 » Tue Sep 01, 2020 10:37 pm
I have a [Standard Horizon] GX2200 [VHF Marine Band DSC Class D radio] with its own internal GNSS receiver.
I plan to [interface the GX2200] to my GARMIN chart plotter. A GARMIN representative said I could just hook up the wiring for AIS and forget about hooking up the wiring [to get boat position data from the GARMIN GNSS receiver] since my radio already [has its own GNSS receiver].
I can just [interface the radio to the chart plotter so the chart plotter will show] AIS [targets]?
Or, should I [interface the chart plotter to send my boat position to the radio using its GNSS receiver] as well? If so
If I did, what benefits would occur?
Re: DSC Radio With Internal GNSS Receiver
Postby jimh » Thu Sep 03, 2020 11:44 am
I believe that a Standard-Horizon GX2200 radio has only NMEA-0183 interfaces for exchange of data with other devices.
To interface a GX2200 radio with AIS to a chart plotter, you will use the NMEA-0183 TALKER signal line from the radio and connect to a chart plotter's NMEA-0183 LISTENER signal lines
To interface a GX2200 radio to an external GNSS receiver, you will use the NMEA-0183 input lines to connect to the TALKER signal lines from the external device.
Since the GX2200 radio under discussion has its own internal GNSS receiver, interfacing to an external receiver can be useful to provide a back up source of boat position.
For advice on Standard-Horizon radio interfacing with NMEA-0183 see
viewtopic.php?f=9&t=816#p5296
For advice on Garmin chart plotter interfacing with NMEA-0183 see
viewtopic.php?f=9&t=816#p5307
viewtopic.php?f=9&t=816#p5350
viewtopic.php?f=9&t=816#p12067
viewtopic.php?f=9&t=816#p12390
Note that GARMIN uses very inconsistent wire colors and non-standard interfaces.
Postby Jefecinco » Fri Sep 04, 2020 8:58 am
Standard Horizon makes well regarded marine band VHF radios. However, if one plans to interface such a radio with other marine electronic devices it may be useful to consider devices designed to be interfaced with a NMEA 2000 network for ease of installation and simplicity of the interface wiring. Simrad is a manufacturer marketing NMEA 2000 compatible devices.
Postby jimh » Fri Sep 04, 2020 11:26 am
VHF Marine Band DSC radios have their own topic forum.
Standard-Horizon makes a VHF Marine Band 25-Watts fixed-mount Class-D DSC radio with both NMEA-0183 and NMEA2000 interfaces. See the VHF Marine Band Radio forum at
viewtopic.php?f=13&t=5237
