Propellers for High Altitude
Don SSDD
Postby Don SSDD » Mon Feb 01, 2021 7:00 am
If a boat engine is losing power at high altitude, should a different propeller for high altitude than used at sea level be considered?
Nova Scotia
Re: Will Fuel-Injection Improve Engine Performance at High Elevations
Postby jimh » Mon Feb 01, 2021 8:32 am
DON--I believe that changing the propeller to accommodate reduced engine power output at altitude is a common technique used by boaters. To change a propeller takes only a few moments.
Many boaters also change the propeller to accommodate unusual loading situation, particularly on smaller boats where changes in weight aboard can be significant percentage changes in total weight.
Postby Phil T » Mon Feb 01, 2021 10:13 am
Don -
If an owner has a carbureted outboard, installing larger jets can help mitigate some of the impact of the air density change. One can also use a lower pitch prop as well but you can only go so far.
In a handlful of cases I know a prop change has helped. In several instances, all high elevation (8,000'+), a repower was required.
Pogiepika
Postby Pogiepika » Mon Feb 01, 2021 7:43 pm
jimh wrote:I believe that changing the propeller to accommodate reduced engine power output at altitude is a common technique used by boaters.
The shop [that is selling me a new engine] said I certainly would need [two] different propellers: one propeller for high altitude, and one propeller for the coast [at sea level]. The shop said they have a lot of experience in getting the correct propellers for high altitude.
