When looking at the data, it shows my boat having a negative slip, which isn;t possible. Here's how I've done the testing.
SPEED and location tested. GPS speed on my Garmin plotter and also a separate GPS running Navionics 45 and 45.1MPH were the recorded speeds.
1. Salem Harbor at the end at slack high tide so there was moving water to influance and there was no perceivable wind on the day tested. The run was a "back and forth" average which was within 2/10ths of a MPH.
2. RockHaven Lake in Maine, again no current and no perceivable wind. Speed was within 1/10th of a MPH on a back and forth run over the same location.
Engine RPM
The Yamaha F70 was turning 6300RPM which is on the rev limiter, so it cannot turn any faster in both cases above.
Gear Ratio - the F70 runs a 2.33 gear ratio, which is confirmed by Yamaha specs
Propeller pitch - the current prop was purchased new from Powertech propellers and is a RAF3 Stainless in a 17". I've confirmed this by looking at the information on the prop.
What is strange is my prop slip number is negative in both calcualtors (-3 and -3.4%). I'm not questioning the calculation between the two, but the fact that it's negative.
The boat in the test was carrying about 8 gallons of fuel, myself as the driver and roughly 100# in gear, so a very light boat. The motor is on a jackplate raised a full 6" above the transom lip. The motor was also tilted to the max trim position, so there is very little boat to water contact. I've talked with other 15' owners and I'm told an SCD18" or 19" pitch should provide me a high top end speed.
The only wildcard would be a prop that was mismarked at the factory and is possibly a taller pitch, but even if it's an 18" pitch, then slip is still only 2%. I am going to pull the prop and measure the pitch over the weekend to confirm the pitch.
For me this isn't about having the fastest 15' Whaler, it's more about dialing in everything to perfection. The boat spends most of it's time in the sub 30mph range.
