1984 Quicksilver Remote Control Parts List and Diagram
tomolalla
Postby tomolalla » Sat Feb 12, 2022 10:11 am
Where can a parts list and pictorial diagrams for a c.1984 Quicksilver remote shift and throttle control be found?
Fig. 1. Quicksilver top-mount remote shift and throttle control.
The trim-tilt [electrical switch] that fits inside the shift handle needs to be replaced. Inside a plastic cover is the number 87468.
Now that I've taken the handle partially apart, I'm having trouble aligning the shift handle; any advice would be appreciated.
MarkCz
Re: 1984 Quicksilver Remote Control Parts List and Diagram
Postby MarkCz » Sun Feb 13, 2022 5:34 pm
I have that same Mercury Quicksilver top-mounting remote shift and throttle control with the tilt-trim switch. I also have not had any luck finding a parts diagram for that unit. If my tilt trim switch ever needs to be replaced I would consider adding a dash panel mounted tilt trim switch.
Does the switch have any identifying part numbers on it?
Postby Phil T » Sun Feb 13, 2022 7:50 pm
Have you contacted a Mercury dealer's parts department and asked them?
I would start there.
Re: Quicksilver Remote Control Parts List and Diagram
Postby jimh » Mon Feb 14, 2022 8:35 am
Mercury is generally not very good about providing service manual literature on-line for free download, so I would not expect to be able to get an exploded view pictorial diagram or complete parts list.
I recommend you contact a local Mercury dealer who has been in business with Mercury for about 50-years. A dealer who was selling Mercury in c.1984 might have the replacement part you need for the Quicksilver control sitting on a dusty shelf. A switch used 38-years ago may no longer be in the current replacement part inventory in 2022.
frontier
Postby frontier » Mon Feb 14, 2022 11:02 am
Try Sea-Way Marine in the Seattle area (425-412-4006). Great vendor for new old stock outboard parts. They've been around since the late 1950's.
tomolalla
Postby tomolalla » Tue Feb 15, 2022 9:23 am
I appreciate the help. I will try contacting a Mercury dealer.
Ironically, I just moved the boat from the Seattle area (where Sea-Way Marine is located) to my retirement place in Florida. Sea-Way Marine helped me many years ago as a student with my 1972 Mercury 7.5-HP engine.
Who is an old-time Mercury dealer in Florida, and especially in the Tampa area?
tomolalla
Postby tomolalla » Wed Feb 23, 2022 7:04 pm
I found a part number: 88688A14.
I found exploded diagrams and parts are available from Crowleys and others.
Postby jimh » Thu Feb 24, 2022 9:18 am
Perhaps to make your newly found information about internet resources more useful, you can give a URL to the exploded view diagram and parts lists that you found that have been the topic of this discussion.
Postby jimh » Fri Feb 25, 2022 7:04 am
DT--many thanks for posting a link to the actual information that has been sought and is the topic of this thread.
tomolalla
Postby tomolalla » Sat Feb 26, 2022 4:50 am
Several other venders besides Crowleys are available for that console control too.
Postby jimh » Sat Feb 26, 2022 7:34 am
If you wish to inform readers that several other resources are available, please give the URL to those resources.
