Length of Lower Drain Tube, 1969 16-footer
Keyaskom
Postby Keyaskom » Fri Apr 29, 2022 3:29 pm
On a 1969 16-footer, I noticed the "lower" drain tube does not go completely through the transom. The drain tube only goes about 5 to 6-inches then stops. I can feel an opening with my finger from inside the boat. I used a string to push through and measure. The measurement was 20 to 22-inches.
Is a measurement [of the length of a "lower" drain tube on a c.1969 16-foot hull] correct?
Re: Length of Lower Drain Tube, 1969 16-footer
Postby jimh » Fri Apr 29, 2022 7:10 pm
Are you asking about the length of the drain from the aft cockpit sump to the outboard face of the transom?
Tom Hemphill
Postby Tom Hemphill » Sat Apr 30, 2022 11:36 am
In a 16-foot Whaler of that vintage, the length of the lower drain tube is 13 inches. You may have hidden damage on yours, indicating it should be replaced.
Sg5054
Postby Sg5054 » Tue May 31, 2022 7:28 am
If you want to make the brass drain tube problem go away permanently, get a length of 3/4 ID fiberglass tubing from McMaster Carr. Using a hole saw drill out both ends to the tube OD. Fit it as needed and glass it in. Problem solved permanently.
I’ve done this to all the whalers I have owned(5).
