BECKSON Clear Pry-out Deck Access Plate: Removing Fogging and Scratches
Don SSDD
Postby Don SSDD » Wed May 25, 2022 2:02 pm
How can fogging and scratches in a BECKSON clear circular pry-out deck access plate be removed?
I tried Plastx by Meguiar's, but it doesn’t work on this material.
Don
Nova Scotia
Re: BECKSON Clear Pry-out Deck Access Plate: Removing Fogging and Scratches
Postby jimh » Wed May 25, 2022 2:11 pm
The BECKSON clear pry-out deck access plates used typically to cover the fuel tank access point where the fuel tank level gauge is located can still be obtained from the OEM supplier for $38. That includes a new surround ring and the pry-out plate. I do not believe BECKSON sells just the clear pry-out plate.
See the article in the REFERENCE SECTION on the TOPIC of
Original Equipment Manufacturers and
Recommended Vendors
https://continuouswave.com/whaler/refer ... tml#pryout
Don SSDD
Postby Don SSDD » Wed May 25, 2022 2:22 pm
Very good Jim, that is a great deal for $38 these days. Thanks, Don
Nova Scotia
Postby Phil T » Wed May 25, 2022 3:35 pm
Don - Consider wet sanding?
Don SSDD
Postby Don SSDD » Wed May 25, 2022 8:36 pm
What’s the process Phil? Not experienced but can take a crack at it.
Nova Scotia
Postby Phil T » Thu May 26, 2022 11:04 am
It is similar to woodworking.
Start with a grit and work finer. I would start at 1000 grit, then step up to 1500 and then finish at 2000.
Don SSDD
Postby Don SSDD » Thu May 26, 2022 1:00 pm
Thanks Phil, I’ll give it a try.
Nova Scotia
