E-TEC G2 Overheat Warnings
briansmith
Postby briansmith » Thu Jun 09, 2022 6:06 pm
I have a pair of 2018 E-TEC G2 200 H.O. engines.
The port engine always runs about 20 to 30-degrees-F hotter than the starboard, at my normal cruise of 3100 to 3200 rpm.
Sometimes, the [port] engine will hold steady at 160-161 for a long time. Sometimes, it blows right past 160 and goes up to the high 170's, then stays steady there for a long time.
Sometimes I get a high temp warning after running around 160-degrees for a long time.
Sometimes I get a high temp warning after running in the high 170'-degree range for a while.
Today, I got a couple of them that happened after coming off plane, and idling for a minute or two, and the displayed temp was definitely around 140-degrees
Q1. what SHOULD the temp be when running at 3100 to 3200-RPM?
Q2. do the symptoms I've reported seem like a sticky thermostat?
Q3. Why would there be a high temp warning when one does not seem appropriate?
Re: E-TEC G2 Overheat Warnings
Postby jimh » Fri Jun 10, 2022 7:41 am
You should move your inquiry to the ETECOWNERSGROUP website. They have organized their forum by specific engine models.
See: https://www.etecownersgroup.com/?forum=377900
Diagnosis of engine cooling system problems for E-TEC G2 engines is well outside the the normal range of discussion here.
briansmith
Postby briansmith » Fri Jun 10, 2022 9:12 am
Thank you, I'll do that. Sorry, I misinterpreted the name of this forum.
Interpreting the forum name "THE GAM."
Postby jimh » Thu Jul 14, 2022 3:32 pm
briansmith wrote: I misinterpreted the name of this forum.
The forum name, THE GAM, refers to a conversation between whale boats when at sea. The forum is for discussions of topics of interest to owners of Boston Whaler boats, most often the Boston Whaler boats themselves.
