Gasket for PERKO Red-Green Lens in Navigation Lamp
OldKenT
Postby OldKenT » Sat Jun 18, 2022 5:18 am
Below is an illustration showing how the red-green lens assembly uses a gasket to keep out water from the interior of a combined red-green sidelights navigation lamp made by PERKO and often used in mid-1980's Boston Whaler boats.
Fig. 1. PERKO combined sidelights navigation lamp oten used
by Boston Whaler c.1985.
IMG_0853 (2).JPG (109.33 KiB) Viewed 2192 times
Fig. 2. Close-up view of gasket with legends GREEN, RED, BULB USE PERKO FIG. 71.
Fig. 3. Close-up view of wire terminal. Note soldered ring terminal connector.
1985 Newport 17
2018 Yamaha F70LA
2017 LoadRite 5S-172200
Re: Gasket for PEKO Red-Green Lens in Navigation Lamp
Postby jimh » Sat Jun 18, 2022 5:00 pm
OLDKENT--Many thanks for the excellent illustrations. You have revealed some great details of the very commonly used red-green combined sidelight lamp often mounted at the bow of Boston Whaler boats. This thread is a good example of the purpose of the website: to collect and organize information on the covered topics.
I am very impressed with the vertical mounting of the miniature electric light bulb. I think that is called a Festoon bulb, or more precisely, a double-ended 12-Volt Festoon bulb. The vertical orientation of the bulb filament should produce very uniform lighting over the range of horizontal arc (12.5-degrees on each side from dead ahead) in which the light is to be shown.
PERKO is known for quality navigation lighting.
More information about their legacy lamp products:
https://perko.com/legacy_catalog/public/books/pdf/cat300.pdf
In the above publication, the Festoon bulb noted as "FIG. 71" can be found on page 65.
