2000 Dauntless 14 Fuel Tank Level Sender Size
Ccarrega
Postby Ccarrega » Sun Oct 16, 2022 10:36 am
What size in inches does the [fuel tank level] sender [for a 2000 DAUNTLESS 14] need to be?
[Moderator's note: this post revived a discussion that had been dormant for over six years on another topic. Please do not expect participants in discussions that took place six years ago to be still following their thread and ready to answer questions on new topics. The new question has been separated from the dormant thread and has become a new thread with a new topic in THE GAM.]
Re: 2000 Dauntless 14 Fuel Tank Level Sender Size
Postby jimh » Sun Oct 16, 2022 11:48 am
Please clarify what dimension of the fuel tank sender you are asking about. There are multiple dimensions associated with a fuel tank level senders, so to infer which one dimension you are asking about will be difficult for readers.
ASIDE: if you want to replace the OEM fuel tank sender, you will need to remove the sender. Once you have removed the sender from the fuel tank you can get plenty of dimensions from the original sender.
