2004 NANTUCKET Combined Sidelights Lamp Part Numbers
houston777
Postby houston777 » Fri Apr 21, 2023 6:46 am
On my 2004 Nantucket 190 on the combined sidelights lamp, a plastic tab on the red-green lens has broken off. This affects the electrical contact.
Fig. 1. Combined sidelights lamp from 2004 190 NANTUCKET.
Q1: what is the part number of the replacement lens?
Q2: what is the part number of the entire lamp assembly?
This lamp uses a 31-mm Festoon lightbulb.
Re: 2004 NANTUCKET Combined Sidelights Lamp Part Numbers
Postby jimh » Fri Apr 21, 2023 7:25 am
Contact your local authorized Boston Whaler dealer to obtain OEM replacement parts.
The red-green combined sidelight lamp with Festoon bulb was probably make by PERKO. See these prior discussions for more information.
Gasket for PERKO Red-Green Lens in Navigation Lamp
https://continuouswave.com/forum/viewto ... 47&p=42338
2014 Montauk 170 Navigation Lamp
https://continuouswave.com/forum/viewto ... 53&p=42607
You may be able to source the lens from PERKO. The PERKO catalogue is available at
https://perko.com/legacy_catalog/public ... cat300.pdf
See page 19. See Figure 0972. See SPARE PARTS ORDERING INFORMATION. This may be your lamp. Verify from the dimensions listed.
Postby Phil T » Fri Apr 21, 2023 12:29 pm
My go-to is Nauset Marine, http://www.nausetmarine.com
Email their Parts Department directly at parts@nausetmarine.com
Masbama
Postby Masbama » Sat Apr 22, 2023 12:27 pm
I have the exact same problem with my 2003 190 Nantucket. I have searched everywhere and have spoken with the experts: Sue Lodel and Nauset Marine.
I found out that the part is not available anymore.
[The combined sidelight lamp] was made by Aqua Signal, but they don’t make it anymore. The last time I spoke with Nauset Marine they said they were working on a LED conversion kit. Looking at the website it appears they now have one.
https://www.nausetmarine.com/boston-wha ... -assembly/
I am calling them Monday, April 24, 2023.
houston777
Postby houston777 » Sun Apr 23, 2023 7:33 am
Masamba,
Very helpful, thank you. If you don't mind posting the outcome, I'd love to hear.
Postby jimh » Sun Apr 23, 2023 1:50 pm
I have to say: Wow. NAUSET MARINE (a Boston Whaler dealer in Massachusetts) have really upped their game in the replacement parts area.
Their website related to navigation lamps is very impressive.
Postby Phil T » Sun Apr 23, 2023 5:01 pm
Nauset's Parts Department is very good and supports owners around the world.
They have a dedicated email address and Jason, Justin and Derek are great to work with.
houston777
Postby houston777 » Thu May 04, 2023 11:20 am
Masbama or anyone else dealing with this: as an interim fix I've had good results adding a single-sided foam tape into the top of the stainless steel light cover. The right thickness of foam tape will apply downward pressure on the green-red llens assembly which helps mitigate a missing plastic tab on the green-red lens assembly. I'm sure its not a permanent fix, but easy to implement.
Masbama
Postby Masbama » Fri May 05, 2023 8:40 pm
Houston777, funny you should mention that temporary fix; I did the exact same thing.
