Source for OEM Railing “bracket”
merk175
Postby merk175 » Sat Jun 17, 2023 12:47 pm
Q1: where can a rectangular. threaded, through-gunwale bracket (that goes outside [possibly means outboard] of the gunwale and the screw fasteners thread from the inside [possibly means inboard side] of the gunwale) for the bow railing on a 1989 Montauk [17] be purchased?
Re: Source for OEM Railing “bracket”
Postby jimh » Sat Jun 17, 2023 7:44 pm
In your use of the tern “bracket” do you mean the mounting base for a vertical stanchion that is part of the bow railing that sits on the gunwale and is retained to the hull with screw fasteners and retains the stanchion with a set screw or rivet?
When you use the directional term “inside” did you mean inboard?
When you use the directional term outside did you mean outboard?
merk175
Postby merk175 » Sun Jun 18, 2023 9:02 am
I'm talking about the rectangular plates that are threaded and are placed on the outside gunwale of the hull. The screws for the bow rail bracket go through the bracket, through the hull and thread into this rectangular plate. the bow rail bracket and this rectangular plate effectively are squeezing the gunwale.
[Moderator’s note: if you need advice or help in using the forum software, read the posts in the INTRODUCTION TO FORUM SOFTWARE forum. For example, to learn how to add an in-line image to a post, read this article:
Adding Image to Post
https://continuouswave.com/forum/viewto ... f=1&t=2569 ]
Postby Phil T » Mon Jun 19, 2023 2:05 pm
The technical term for the hardware you are refering to is "backing plate".
Bow Rail Backing Plate - Nauset Marine
They are available from Nauset Marine.
https://www.nausetmarine.com/boston-whaler-parts/hardware/rail-hardware/1067206-backing-plate/
merk175
Postby merk175 » Tue Jun 20, 2023 9:13 am
Thank you for the information.
[The part illustrated above] is [the part I was trying to describe].
