Length of fill hose and vent hose for 2007 Dauntless 180
Tony's Legacy
Postby Tony's Legacy » Mon Jul 17, 2023 2:09 pm
[I plan to] replace the [fuel tank inlet filler] hose and vent hose on my [2007–ALWAYS USE FOUR DIGITS FOR YEAR] 180 DAUNTLESS.
I've looked over the diagrams at
(https://www.bostonwhaler.com/content/da ... t-2007.pdf)
to see what I need, but it says to refer to drawing 01-251 for individual hose lengths. The problem is that I can't find that drawing.
Q1: [IMPUTED QUESTION] what are the lengths [and diameter and necessary USCG APPROVALS] needed for the fuel tank filler hose and the fuel tank vent hose?
Thanks
Re: Length of fill hose and vent hose for 2007 Dauntless 180
Postby Phil T » Mon Jul 17, 2023 2:23 pm
It is not published.
You need to pull the hose to get the exact length or overestimate. Run a garden hose over the deck to simulate path.
Tony's Legacy
Postby Tony's Legacy » Mon Jul 17, 2023 2:51 pm
Thanks for the info. I'll end up estimating because I want to use the old hose to help pull the new hose through.
Postby jimh » Mon Jul 17, 2023 3:23 pm
Murphy’s Law corollary: any rubber fuel hose bought cut-to-length will be too short.
Postby Jefecinco » Wed Jul 19, 2023 10:56 am
Tie a "pull string" to the old hose before pulling it out to measure it. Use the string to pull the new hose into position.
