2001 Mercury 90 Will Only Run at Idle Throttle
GAwhale
Postby GAwhale » Sun Aug 13, 2023 5:48 pm
On August 11. 2023 my 2001 Mercury 90-HP two-stroke-power-cycle engine was set to almost full throttle. I advanced the throttle to full. The engine ran a few seconds then the engine speed dropped to idle. The engine had no power. We had to get home for one hour at idle speed.
It felt like a cable [in the engine remote shift and throttle control system] had snapped.
The engine can go into gear forward, neutral, and reverse.
I have not had a chance to open the engine cowl.
Give me advice on how to repair the engine.
Re:2001 Mercury 90 Will Only Run at Idle Throttle
Postby Phil T » Sun Aug 13, 2023 5:49 pm
Start with the cables.
Pull the cover and inspect the end of the throttle cable. Then check the cable end at the remote throttle control.
GAwhale
Re: 2001 Mercury 90 Will Only Run at Idle Throttle
Postby GAwhale » Wed Aug 23, 2023 7:51 pm
I removed the engine cowling [on the 2001 Mercury 90-HP two-stroke-power-cycle engine that would only run at idle speed], and I found the throttle remote control cable linkage [was no longer connected to the actual throttle lever on the engine]. Since the engine was due for routine service, I took the boat to a mechanic for the repair.
The mechanic found there was a loose bushing [or connection fitting]. The bushing was replaced and the throttle linkage was reconnected.
The part number of the bushing that was replaced is 23-932481; the mechanic charged $13.70 for the part.
Postby jimh » Thu Aug 24, 2023 8:00 am
I was curious about the nature of "the bushing" and searched on the part number. The search returned an enormous number of "hits" for this part. I suspect it might be something commonly replaced. You can see what the part looks like at this seller's website:
https://bayareapowersports.com/linkage- ... -23-932481
The bushing or connector looks like it is made of nylon or other plastic material, and makes a snap fit or a compression fit to whatever it mates with. Perhaps after 22-years the bushing lost its elasticity and could no longer retain the connection to the remote control cable.
GAwhale
Postby GAwhale » Thu Aug 24, 2023 8:57 am
Service life of 22-years is probably a good life for a plastic bushing. It is the first time the linkage ever disconnected since I bought the boat and engine new. Perhaps the very hot weather we get in the South was a factor.
