Outrage 18; Yamaha 150 HPDI
stingraze
Postby stingraze » Mon Apr 25, 2016 8:00 pm
http://s4.photobucket.com/user/stingraze/media/Mobile%20Uploads/20160424_110505.jpg.html
I got my Outrage 18 from the mechanic after he installed a Yamaha 150 HPDI. I am very pleased with the performance, especially [the reduction in] fuel consumption compared to the former Mercury 150-HP carbureted engine. The Yamaha 150 HPDI is 77-lbs heavier than the old engine, so looks like a battery relocation is next.
Re: OUTRAG 18; Yamaha 150 HPDI
Postby jimh » Tue Apr 26, 2016 12:52 pm
A fellow local to me, Tony in Omena Bay, has an OUTRAGE 18 with a Yamaha 150-HP HPDI engine. I looks like a very good combination. I am sure you will be very pleased with the performance. At 150-HP you have the OUTRAGE 18 at its maximum rated power.
Tight line
Postby Tight line » Tue Apr 26, 2016 8:46 pm
A year ago, I put a [different 150-HP engine, a Yamaha] F150 on my 18-footer. It jumps onto plane in a heartbeat and the peace of mind that accompanies a new engine is well worth the cost.
Peter
Re: Outrage 18; Yamaha 150 HPDI
Postby Peter » Wed Apr 27, 2016 7:24 am
I have two of the HPDI 150 engines. Advice: make sure you have a boat-mounted fuel-water separator that is maintained regularly. The HPDI fuel system is very sensitive to contamination.
stingraze
Postby stingraze » Wed Apr 27, 2016 8:55 pm
Thank you for the fuel-water separator suggestion. I do have one in place, especially after mechanic told horror stories of water getting into injectors and the damage it can cause. I have witnessed too many people run water into engines, which could have been prevented with a separator.
