2018 270 DAUNTLESS Pump Runs Continually
Csal7099
Postby Csal7099 » Sun Mar 31, 2024 11:37 pm
On my 2018 27O DAUNTLESS, when the battery switch is in the OFF position, I hear a pump running and circulating water within the boat.
This also occurs when the boat is running.
I am concerned that a continually operating pump will discharge the boat battery.
Q1: how can a pump on a 2018 270 DAUNTLESS that seems to run even with the battery switch in the OFF position be shut off?
Re: 2018 270 DAUNTLESS Pump Runs Continually
Postby jimh » Tue Apr 02, 2024 8:25 am
The typical wiring scheme on a modern Boston Whaler boat, like a 2018 270 DAUNTLESS, will have an isolated feed from the main battery that remains on even when the main battery switch is set to the OFF position.
This circuit is typically protected by a fuse or a circuit breaker, and provides power to a lift pump in a sump area of the boat that is intended to lift water from the sump area upward and to an overboard exhaust passage to the sea.
Typically the sump area will also have a though-hull fitting that drains the sump downward. This drain is usually closed with an inserted plug when the boat is in the water, preventing seawater from flowing into the sump. The lift pump in the sump will only run when water accumulates in the sump from runoff water on the deck.
If the sump drain is left open while the the boat is in the water, the lift pump will run continuously, lifting water out of the sump and back to the sea.
To stop the lift pump in the sump from running, install the plug in the sump drain.
The drain in the sump should only be left open when the boat is out of the water, as when on a trailer on raised on a boat hoist.
The owner’s manual should explain the operation of the sump, the drain, and the lift pump.
The detailed electrical wiring diagram should show the branch circuit providing power to the lift pump that is not in the circuit controlled by the main battery switch.
You should be able to download those publications from the whaler.com website. Look for the links in the “Owner’s Resources” area.
MarkCz
Postby MarkCz » Tue Apr 02, 2024 10:40 am
If your bilge pump has a float switch to turn on the pump it may be stuck in the on position.
