Dexter E-Z-Lube Spindles
Postby jimh » Sat Apr 19, 2025 11:36 am
To see a short and well-done two-minute 14-second motion picture and sound presentation about the Dexter E-Z-Lube Spindle and axle, visit youTube at
https://www.youtube.com/watch?v=XT0RKDGgDm8
On the other hand, another youTube video proposes to show the grease system will tend to blow out the rear main seal and contaminate the brakes. You can start watching at this point:
E-Z Lube Hubs Exposed
https://youtu.be/1B_E7khBenQ?t=134
Most of the comments about this presentation point out that the demonstration is not particularly valid because the whole system was not in place. When all components are in place, rear seal, inner bearing, outer bearing, front seal, retainer washer, nut, locking mechanism, the grease will tend to flow as intended, as long as the rear seal is in place and the exiting grease has not hardened and won't easily be pushed out.
Useful comments cite the requirements for successful use of the E-Z-Lube system:
  • the wheel MUST be rotated continually as the new grease is pumped in;
  • only perform greasing on a warm day;
  • be sure the grease temperature is warm; and
  • pump in the new grease slowly
Leaving the grease, the grease gun, and the wheels sitting in the sun for several hours is recommend before re-greasing.
A very cogent comment mentions that for each pump-in of new grease, you should see a corresponding appearance old grease escaping. If you do not see that occurring, then the new grease may just be blowing past the rear grease seal.
Another comment--perhaps the best--cites the machined exit hole for the grease as having a sharp edge. The sharp edge tends to cut into the grease seal, reducing its effectiveness. That user recommends de-burring the the machined hole edges. If you do this, be sure to remove any metal shavings or particles created in the process.
A further caution is to AVOID using a powered grease gun; always pump in the new grease using a hand operated grease gun.
The most reliable method for boat trailer wheel bearing maintenance may be a periodic complete disassembly of the the bearings and seal, replacement of the grease seals, cleaning off of old grease, and re-greasing with new grease, including preloading the bearings with grease (which can be done with a handy plastic cone accessory). That is much more work than using the E-Z-Lube method, and might not be possible for everyone do accomplish.
fno
Re: Dexter E-Z-Lube Spindles
Postby fno » Fri May 02, 2025 6:18 pm
I have plenty of experience with this type of hub and spindle arrangement. Not just on my boat trailer but two other cargo trailers and a smoker on a trailer. There is nothing inherently a poor design as long as the inner seal is doing its job. All of the grease will come out from the cup side if that's the case. Often, and the second video may be an example is if the spindle exhibits wear in the grease seal area which may or may not be more common with waterlogged boat axles. In my experience, I purchase stainless steel spindle liners that get tapped onto the spindle (with some RTV inside) I have had zero problems with these seal liners rusting or coming loose over time. Nor do I have any grease leaks at the inside of the spindle and or hub. And I still can use standard sized seals. Another FYI is to use a good red grease from Mobile or Havoline. The hubs can and do fill up with water sometimes but these two greases seem to protect the bearings regardless. BTW, it is important to use quality bearings in a boat trailer hub. Most of the offerings at hardware, boating shops, and internet are inexpensive bearings from China or worse. SKF and Timken bearings are harder to find for a trailer but well worth the search and cost. Being on the side of the interstate with a flat tire just plain sucks. Being there with a blown axle is way worse and might involve a flatbed wrecker.
fno
Postby fno » Fri May 02, 2025 6:20 pm
BTW, I agree with all of what JimH suggests and just wanted to add my two cents to the conversation.
Postby Jefecinco » Sat May 03, 2025 9:38 am
I recommend your spare tire be equipped with a new hub with bearings installed. It can save a lot of time, bother and expense when a failure puts you on the shoulder.
