MONTAUK 17 Through-hulls Drains
mcamuso
Postby mcamuso » Tue Apr 22, 2025 3:06 pm
Q1: in what model year of the MONTAUK 17 were through-hull drains switched from the traditional brass construction to plastic or nylon parts?
Re: MONTAUK 17 Through-hulls Drains
Postby jimh » Wed Apr 23, 2025 5:57 pm
Q2: can you identify ANY classic MONTAUK hull in which its original through hull drain was using plastic parts?
duckcall07
Postby duckcall07 » Fri May 02, 2025 4:25 pm
My 2000 Montauk 17 through-hull drain fittings are plastic. I am sure they are the OEM original parts
