1979 MONTAUK 17: Source for metal trim used to prevent chafe on fuel hose.
piscator
Postby piscator » Fri May 16, 2025 11:38 am
Q1: where can the trim piece for the fuel line [where it enters the rigging tunnel on a 1979 not 79-feet] MONTAUK 17 [and appears identical to the hawse pipe trim used on many Boston Whaler gunwales for access to the stern cleats mounted on the inwales] be purchased?
Fig. 1. A metal trim piece
[Moderator’s note: please start a new thread if you wish to show the restorted 1979 MONTAUK when completed. Please use four digits for model years. Please NEVER use an apostrophe following two numbers as a way to indicate a year. When an apostrophe follows numbers the meaning is “foot” or “ feet.” Deleted uploaded file as it was a PHP script and not an actual photograph image file. Please do not upload PHP scripts. Please read the article in the INTRODUCTION TO THE FORUM SOFTWARE on this and other writing style preferences. See https://continuouswave.com/forum/viewto ... f=1&t=3844. ]
MarkCz
Re: Hawspipe
Postby MarkCz » Sun May 18, 2025 8:19 am
That trim piece is known as a hawse pipe. There are quite a few aftermarket hawse pipes made in different sizes available. If no one on the forum has a part number for that exact one, I would just start searching hawse pipe and see if you can find one that is the same size and maybe has the same hole spacing.
Re: 1979 MONTAUK 17: Source for metal trim used to prevent chafe on fuel hose.
Postby jimh » Sun May 18, 2025 10:17 am
What is wrong with the original? You can probably clean that up to look like new in ten minutes.
Postby jimh » Sun May 18, 2025 11:32 pm
For unusual parts for older Boston Whaler boats, two good sources are
  • NAUSET Marine
  • TWIN CITIES Marine
See the two articles at the top of THE GAM forum for the latest contact information for them.
TWIN CITIES
https://continuouswave.com/forum/viewto ... f=4&t=1551
NAUSET
https://continuouswave.com/forum/viewto ... =4&t=8191R
