1994 OUTRAGE 19: Source for Replacement Bow Eye
RobertV
Postby RobertV » Sat May 17, 2025 1:10 pm
Q1: where can a replacement bow eye for a 1994 OUTRAGE 19 be purchased?
The original bow eye uses a 5/8-inch-diameter, threaded, U-shaped steel rod. [The left side as seen in Figure 1 (below) broke and is shorter than the longer right side, which measures] 12-inches [from] the front of the eye.
Fig. 1. The original bow towing eye from a 1994 OUTRAGE 19.
bow eye.jpg (85.95 KiB) Viewed 1455 times
ASIDE
I attempted to weld the original rod (at the break), but my novice welding skills didn't yield a satisfactorily strong result.
PLAN B
If [a suitable replacement is not available], I may seek out a professional welder [to re-weld the original bow eye].
Re: 1994 OUTRAGE 19: Source for Replacement Bow Eye
Postby jimh » Sun May 18, 2025 9:35 am
Q2: is the bow eye fashioned from stainless steel?
Q3: was the left rod shorter in the original rod?
Postby jimh » Sun May 18, 2025 11:30 pm
For unusual parts for older Boston Whaler boats, two good sources are
  • NAUSET Marine
  • TWIN CITIES Marine
See the two articles at the top of THE GAM forum for the latest contact information for them.
TWIN CITIES
https://continuouswave.com/forum/viewto ... f=4&t=1551
NAUSET
https://continuouswave.com/forum/viewto ... =4&t=8191R
