1997 STANDARD Rigging Tunnel
Deshazo63
Postby Deshazo63 » Fri Jun 06, 2025 7:30 am
Q1: on a 1997 STANDARD is there a rigging tunnel that would facilitate adding a center console?
I have a 1997 STANDARD and I am adding a center console.
[Moderator's note: when identifying any Boston Whaler boat, you need to give the MODEL YEAR, the FAMILY, the LENGTH, and the TRANSOM CONFIGURATION (if there were options for the transom configuration on that model) to properly identify the boat. For example, a "1987 OUTRAGE 22 Notched Transom."]
Re: 1997 STANDARD Rigging Tunnel
Postby jimh » Fri Jun 06, 2025 9:45 am
The presence of a rigging tunnel on any Boston Whaler boat would be visually very obvious. If you don't see a rigging tunnel then there is no rigging tunnel, and particularly so on small open boat models.
Q2: what model are you asking about?
