In recreational boating, there are four types of coaxial cable in common use. The smallest typical cable is referred to as RG-58 and has a diameter of around 0.2-inches. Another common cable is referred to as RG8X and has a diameter of about 0.24-inches and uses foam dielectric insulation. Also useful is RG-8/U-type cable, which has a diameter of around 0.40-inches. A similar size cable, referred to as "RF400-type" also has a diameter of about 0.40-inches, but includes improved gas-injected HDPE foam dielectric insulation, decreasing loss.
All of the cables used in the comparison (below) are products of Belden, and the outer jacket material is designated as non-contaminating (or fire-resistant), which improves durability in sunlight and prevents loss with age. These same types of coaxial cables are available from other manufacturers and may have slightly different rated loss figures, may have contaminating outer jacket material, may have tinned or bare copper conductors, may have different dielectric insulation, and may sell at significantly different prices.
In Table 1 the length of these four cable types that will produce a loss of -1 dB is shown.
Length for 1-dB loss at 150-MHz (using Belden products)
RG-58/U = 16.4-feet (Belden 8262) Solid polyethylene dielectric, 0.195-inch OD
RG-8X = 26.3-feet (Belden 9258) Foam polyethylene dielectric, 0.242-inch OD
RG-8/U = 43.5-feet (Belden 9251) Solid polyethylene dielectric, 0.405-inch OD
RF400 = 66.7-feet (Belden 7810A) Gas-injected foam HDPE dielectric, 0.405-inch OD
Table 1. Length of various types of coaxial cable to cause a loss of -1 dB at 150-MHz
For length for -0.5 dB loss, just reduce the feet to half the value shown.
The above is based on the indicated Belden product numbers, and (if necessary) linear interpolation of loss at 100 and 200-MHz, resulting in the following loss figures for 100-feet of cable:
Rated Loss from Belden Specifications for 100-feet at 150-MHz
RG-58/U = -6.1 dB (Belden 8262)
RG-8X = -3.8 dB (Belden 9258)
RG-8/U = -2.3 dB (Belden 9251)
RF400 = -1.5 dB (Belden 7810A)Table 2. Rated loss of various types of coaxial cable for 100-feet at 150-MHz
The executive summary: if cable loss is expected to exceed -1 dB at 150-MHz due to length, move up to a larger-diameter cable.
