1985 MONTAUK 17: Source for plastic cover for wiring
ddqarch
Postby ddqarch » Tue Jun 24, 2025 8:23 pm
Q1: where can I find a replacement for a black plastic 2-inch by 4-inch housing on my 1985 Montauk 17 that covered wiring for the navigation lamp and had a rubber grommet at the bottom?
I recently had to remove that cover, held on with 4 screws, to work on the wiring. It seems it was glued as well as screwed in place, and broke in half when I tried to pry it off.
bjohn
Re: 1985 MONTAUK 17: Source for plastic cover for wiring at stern
Postby bjohn » Tue Jun 24, 2025 11:50 pm
I encountered a similar problem on my 1981 Montauk 17. I fabricated a replacement by modifying a generic waterproof junction box.
Fig. 1.
I drilled a hole in the back of the box (the side facing the hull) for the navigation light wiring to pass through. Another hole was drilled in the bottom of the box (facing down towards the deck), and a Blue Sea brand cable gland was was installed to provide a weatherproof seal for the wiring. The wiring connections were made inside the box using a small terminal block and appropriately sized ring terminals.
Waterproof junction boxes, such as the one I used, are commonly available on Amazon. For example:
https://www.amazon.com/dp/B092HS9CMR/re ... k_detail_0
I've had the junction box installed on my boat for about four years. It's proven to be a very effective solution and keeps the wiring connections completely dry and out of the elements. If you do order a junction box from Amazon, I'd recommend replacing the supplied "stainless steel" screws with better hardware. The screws that were supplied with the box I ordered were completely rusted after one season on the water.
Postby jimh » Wed Jun 25, 2025 8:46 am
Using a tan or beige color for the plastic enclosure would be a big improvement over using a black box.
In the installation shown in Figure 1, the cable for the white all-round pole lamp seems to be permanently connected via the junction box. This appears to prevents the pole lamp from being removed from its mounting.
Other articles also discusses this circuit and the housing. See
Wiring for Navigation Lamp
https://continuouswave.com/forum/viewto ... 48&p=37139
Electrical Terminal Block for Navigation Lamp Wiring
https://continuouswave.com/forum/viewto ... 32&p=31521
SPORT 15 Cover for electrical terminal block
https://continuouswave.com/forum/viewto ... 78&p=17033
MarkCz
Postby MarkCz » Wed Jun 25, 2025 10:02 am
To locate boat-specific part numbers, find your boat model in the link below:
https://www.nausetmarine.com/boston-wha ... -diagrams/
Then download the PDF files that show the parts diagram for your boat. Once you have the part number you can call a good Boston Whaler authorized dealer [like NAUSET Marine or The Boat House] and ask them to order you the part for you.
Also visit this resource for more information on how to a plastic cover from NAUSET Marine in Massachusetts:
https://www.facebook.com/photo.php?fbid=2761700227195598
