Montauk 90 E-TEC musings
kwik_wurk
Postby kwik_wurk » Mon Jun 06, 2016 8:00 pm
Musings of a new E-TEC 90 owner [after] logging 12-hours in first fishing outing, in weather that ranged to flat calm to 25-kts wind in 7-foot seas with 8-secoind interval and very yucky stuff:
The good:
--Very quiet for a two stroke engine (especially at idle).
--Fuel consumption at lower RPM very very impressive. Much better than older 90 Mercury, 35% better. Fuel consumption at mid-upper ranges still improved, but not as drastic, 15% better. May be related to prop and speed mentioned below.
--Oil consumption better than expected even through the break in period.
--[acceleration at full throttle from a standing start] was acceptable; mid range "pop" was great as in going from 3400 to 4500 RPM; little-to-no blow out when cornering. I have yet to waterski, so loaded [acceleration at full throttle from a standing start] is [to be determined].
--Nice to have a engine that starts every time without too much feathering; I hope this continues for life of the engine.
-three-year-maintenance free: it’s gonna be hard not to tinker on the engine.
The bad:
--Trim/tilt is rather slow. Past outboard had a two speed trim and tilt and hence faster for full tilt and trim in and out of the water.
--BRP [top mounting remote control] is rather awkward and not ergonomical on a classic console. It is narrow and tall, and slightly (1/4-inch) longer and larger than the flat surface on the console it mounts to, hence a slight bit over overhang. The older Mercury or Qucksilver was smaller and one could rest hand and hold on to throttle lever on whilst driving.
--it shakes the console and one rail whilst at idle. Past engine physically shook more; but did not bother boat, E-TEC has very stiff dampening and shakes the boat more. Tail wagging the dog syndrome. All hardware is bedded, but the one sloppy (egged out) railing standoff is the offender.
-A little slower than expected, or requiring slightly higher RPM (150-200) to achieve same hull speeds; see comments below.
Fine tuning the mounting and propeller: [see drawing below for mounting height] running a Viper 19 pitch, my top speeds 33.8-nautical-miles-per hour or 38.9-MPH at 5,500 RPM. The boat had bottom paint, 15-gallons fuel, anchor and other common gear, battery in console. This top end speed seems off to me; it seems I should crack 40-MPH or 41-MPH, which is only 1 to 2-MPH away. Against the Mercury prop calculator this means 22-percent SLIP with the Viper 19P at 5,500 and 2.00:1 gear.
http://www.mercuryracing.com/prop-slip-calculator/
I can’t tell if I am hitting the rev limiter; is it hard RPM stop at 5,500-RPM? Or, is higher like 5650-RPM? As I hit 5500 and still have a little more travel on the throttle lever, but not sure if there is anything there.
Also my intermediate speeds seem slower too. Specifically, I used to get 19 to 20-nautical-miles-per-hour at 3000-3100 RPM on my old Mercury 90, with a Mercury 19P (but professionally re-cupped so little slip). I have to push the E-TEC up a little higher to 3300 to 3400 to get that speed.
Tried to search the old forum for a like-like comparison, but found Montauks with jack plates, or different props etc. Another member recently talked about a 17 Viper 3 holes up (which seems odd). -- Any one else with a Viper 19P on the forum. Any other notes to compare against.
I hate to “try out” mounting heights, as that’s a lot of 4200 to break up. The dealer had several classic whalers in the lot. So confidence in their work, I am a bit puzzled. -- I have not had an extensive chance to do quality speed runs on reciprocal course, I hope this weekend to have clean water to do so. (My speed test was done with slight wind chop, but I was able to trim out as warranted.)
Mounting height (I'll get a measurement of inches above keel CL to the cavitation plate is, as there are a lot discrepancies on hole position vs resultant height.)
o
o<-This one
o
o
Re: Montauk 90 E-TEC musings
Postby Phil T » Mon Jun 06, 2016 9:06 pm
E-TEC engines like to be mounted HIGH. I would go up at least one or two holes.
kwik_wurk
Postby kwik_wurk » Tue Jun 07, 2016 12:39 am
For the sake of clarity, the mounting position shown in the first post has the engine sitting about 0.8-inch above the top transom (expected 0.75-inch up). This puts the cavitation plate 1.5-inch above keel when trimmed all the way in, and when trimmed to "running condition" the [anti-ventilation plate] is about 1.25-inch above keel.
Marc-B
Postby Marc-B » Tue Jun 07, 2016 12:04 pm
I am possibly the one that posted that my E-TEC 90 was three-holes-up running a 17 Viper. I made an error. The engine mounting height is [ONE HOLE UP as shown below].
O
O- here
O
O
The standard bolt pattern was not respected, the top bolts are higher than standard by about 0.75 inch, I will probably re drill to the next lower hole as I do find it a bit close to the top of the transom, but that is another problem.
I took a straight board and extended a parallel line from the bottom of the keel and measured the distance to the ventilation plate that is also parallel to the board and measured approximately 2.25-inch above keel, not enough hands to be able to get an very accurate measure.
I have yet to do any kind proper performance analysis. I want to do a proper test in 1,000-RPM increments on a light load,. The initial results are that it will rev past 5,500, (analog system check tach) and did get 43-MPH on GPS.
Yes [the E-TEC engine] does make the boat vibrate at idle, but it seems to be getting better, or I am used to it. It made me find all the loose railings.
So far very pleased with performance, but I can only compare to my old 1979 Mercury 80 HP that could not go over 5,200 RPM on a 17-P aluminum propeller.
Jim, if I am not making sense, let me know and I will re-measure.
Kwik_Wurk, I will send pictures to your email
Marc-B
Postby jimh » Wed Jun 08, 2016 5:08 pm
The engine under discussion in this thread appears to me to be described graphically as what we would call mounted "one-hole-up."
Given the conditions described and the sea state, I would not be too worried about speed testing. Test the boat speed in calmer water. Usually a very small wind wave sea state is best for speed testing, even better than dead calm.
Long-term fuel consumption when changing to an E-TEC from a conventional carburetor two-stroke-cycle engine is usually about an INCREASE in MPG by a factor of 1.5 to 1.8.
kwik_wurk
Postby kwik_wurk » Thu Jun 09, 2016 11:52 am
I have not had a chance to splash the boat, despite being 90 last weekend. --- Ideally, I am going to get some testing done this weekend.
Whal
Postby Whal » Mon Jun 20, 2016 10:15 pm
If I am remembering right Tom Clark's recommendation for the E-TEC 90 on a Montauk 17 was a Stiletto Advantage 13.25 x 15 stainless steel propeller with the motor mounted two-holes-up. The Stiletto Advantage 13.25 x 15 was said to actually run like a 17-pitch. They no longer make the Stiletto propellers , but maybe you could find one for sale on eBay or some other site. I hope someone else on here can confirm my memory! I once sold a Stiletto Advandage 13.25 x 15 propeller I had to a guy with a Montauk 17 with an E-TEC 90. Maybe just raising your motor one-hole with your 17 Viper would get your desired results; that's what I would do first. I hope this helps.
RogueII
Postby RogueII » Tue Jun 21, 2016 12:39 pm
You need to mount that motor all the way up:
0
0
0
0 - here
Trust me, you won't regret it. From there, you will be able to go up 2 in pitch to get your RPMs dialed in.
kwik_wurk
Postby kwik_wurk » Tue Jul 05, 2016 11:59 am
Did not get a chance to raise the motor, but did have a chance to look back aft while someone else was driving. -- One hole up is too low, as there is a lot of water flowing over the anti-cavitation plate. Top speed was ~34.1 kts (~39.2 mph) with 2 adults, 1 child and two 5 gallon buckets of crab and seawater. -- Now it's a question of 1 or 2 holes higher.
