1996 19' Outrage II
fina
1996 19' Outrage II
Postby fina » Tue Jun 07, 2016 12:18 pm
[May buy] a 1996 19' Outrage II powered with a 175-HP. The Boston Whaler chart shows that this boat holds a 150-HP. However, I have seen several 1996 models powered with 175-HP
What is the proper maximum horsepower?
porthole
Re: 1996 19' Outrage II
Postby porthole » Tue Jun 07, 2016 6:10 pm
1996 19 Outrage is rated 130/225
Duane
2016 World Cat 230DC
1997 Outrage 18, Yamaha 125
1983 15 SS, Honda 50
1980 42 Post
1983 34 Luhrs 340 SF
fina
Postby fina » Wed Jun 08, 2016 3:54 pm
Is there a weight concern with this model?
fina
Postby fina » Tue Jun 14, 2016 10:36 am
[Seeks] opinions on how the 19 Outrage III [perhaps meant c.1996 19 OUTRAGE] will perform [compared to] a 1987 Outrage 22.
Postby jimh » Tue Jun 14, 2016 1:19 pm
I am a bit confused on exactly what model is being discussed in this thread. In 1996 Boston Whaler made a boat they called the 19 OUTRAGE. This boat is not designated as the 19 OUTRAGE II or as the 19 OUTRAGE III.
The designation 19 OUTRAGE II or perhaps OUTRAGE 19 II is used to describe the boat that was built on the 18-foot 6-inch hull used with the classic OUTRAGE 18. The designator "II" was to differentiate this model from the earlier OUTRAGE 19 made in the 1970's.
The c.1996 19 OUTRAGE is a much different boat than either the OUTRAGE 19, the OUTRAGE 18, or the OUTRAGE 19 II.
The recent mention of an 19 OUTRAGE III seems to introduce another boat.
I think this thread will benefit if we can get a clarification of what boat is under discussion.
Postby jimh » Tue Jun 14, 2016 1:25 pm
If this thread is actually discussing the 1996 19 OUTRAGE, here are some specifications:
LOA = 19-feet 8-inches
BEAM = 8-feet 4-inches
DRAFT = 15-inches
WEIGHT = 2,200-lbs
SWAMPED CAPACITY = 4,800-lbs
MAX. HP = 225-HP
MIN. HP = 130-HP
The boat has the AccuTrack hull design.
In 1997 this same boat was renamed the 20 OUTRAGE.
fina
Postby fina » Wed Jun 15, 2016 9:38 am
The 1996 19' Outrage is called 19' Outrage III
I googled and saw some links referring to the 19' 1996 model as "III".
Price Check- 1996 19' Boston Whaler Outrage III
Did i finally stump JIMH?
Postby jimh » Wed Jun 15, 2016 8:14 pm
Please point to some literature from Boston Whaler with that nomenclature for the 1996 19 OUTRAGE.
I am still not sure what boat you are asking about; please clarify.
