continuousWave --> Whaler --> Reference
E-TEC Recommended Engine Speed Range
by James W. Hebert
Suggested engine operating speed ranges for 2009 E-TEC motors
2009 RPM QUICK REFERENCE CHART
ModelRecommended
Operating Range
Optimum RPM Range
25 HP5000 - 60005400 - 5800
30 HP5000 - 60005400 - 5800
40 HP5000 - 60005400 - 5600
50 HP5500 - 60005600 - 5750
60 HP5500 - 60005600 - 5750
65 HP Commercial5500 - 60005600 - 5750
75 HP4500 - 55005000 - 5200
90 HP4500 - 55005000 - 5200
115 HP (60° V4)5500 - 60005600 - 5700
115 H.O. (60° V4)5500 - 60005500 - 5650
130 HP (60° V4)5500 - 60005500 - 5650
150 HP (60° V6)4850 - 58505500 - 5600
150 H.O. (60° V6)4850 - 58505500 - 5600
175 HP (60° V6)4850 - 58505500 - 5600
200 HP (60° V6)4850 - 58505600 - 5850
200 H.O. (3.3 L 90° V6)4500 - 58005500 - 5600
225 HP (3.3 L 90° V6)4500 - 58005500 - 5600
225 H.O. (3.3 L 90° V6)4500 - 58005500 - 5600
250 HP (3.3 L 90° V6)4500 - 58005500 - 5600
250 H.O. (3.4 L 90° V6)4500 - 58005500 - 5600
300 HP (3.4 L 90° V6)5000 - 60005500 - 5600
The E-TEC engine speed ranges shown in the column "Optimum RPM Range" are believed to be the engine speeds at which the particular E-TEC engine develops its peak horsepower. Selection of a propeller which puts the E-TEC engine into this speed range at wide-open-throttle should produce the best performance.
This chart is adapted from a widely published chart which is believed to be from Bombardier. The chart is often seen in the form of a JPEG image of this text. Presentation of text as rasterized images is an inefficient coding method.
The page has been accessed 9002 times.
Copyright © 2007 by James W. Hebert. Unauthorized reproduction prohibited! Copying and use of this text and graphic images in any form is prohibited without prior permission. Do not cut and paste this text or these images into other on-line documents.
URI: http://continuouswave.com/whaler/reference/ETEC_EngineRPM.html
Last modified: Thursday, 11-Jun-2009 08:24:48 EDT
Author: James W. Hebert
This article first appeared January 2007.
