VHF Sleeve Dipole Antenna Modeling
Postby jimh » Fri Aug 01, 2025 8:42 am
I have been curious about the electrical design of the MORAD VHF-156HD antenna. I believe the general category for this configuration is a sleeve dipole.
A very good article on the design of a sleeve dipole monopole omni-directional antenna appears in an article in the on-line magazine InCompliance, whose general area is electronic design, testing, and standards.
Sleeve Dipole Antenna Design and Build
https://incompliancemag.com/sleeve-dipole-antenna-design-and-build/
In the article the authors describe how they developed a sleeve dipole monopole antenna for 225-MHz use. The physical configuration is very similar to the MORAD VHF-156: there is a whip radiator upper element and a tubular lower element that encircles the radiator.
The design process began by using theoretical dimensions. These were evaluated using modeling software, which was configured to optimize the VSWR for 50-Ohm transmission line. A physical model was then constructed and tested. Then with some trial and error adjustments, the design was finally optimized for the intended resonant frequency of 225-MHz, as the software modeled antenna was resonant at a difference frequency. The final lengths for the two segments to produce resonance at 225-MHz and provide a 50-Ohm feed point impedance were:
    upper radiator = 312-mm
    lower sleeve = 206-mm
Converting the physical dimensions into wavelength λ at 225-MHz = 1332.4-mm
    upper radiator = 312/1332.4 = 0.234 λ
    lower sleeve = 206/1332.4 = 0.155 λ
Now we compare to the MORAD lengths, which I mention in a separate article:
    upper radiator = 0.405 λ
    lower sleeve = 0.299 λ
The agreement is not particularly close. Both the radiator and sleeve are longer, roughly by a factor of about 1.7 (radiator length) to 1.8 (overall length) to 1.9 (sleeve length).
Comparing the overall lengths we see
    225-MHz Sleeve Dipole = 0.389 λ
    MORAD VHF-156 = 0.702 λ
The most interesting inference is the overall MORAD antenna length (0.7 λ) is the region of between 5/8-wavelength (0.625 λ) and 3/4-wavelength (0.75-λ), which in a vertical monopole tends to create gain while maintaining a main lobe with a low angle of radiation. Another inference is the sleeve section is certainly part of an impedance matching section that may also become part of the radiating element.
The strange thing about real world antennas is sometimes their physical design is just developed by trial and error, and then the theory of how it actually works is inferred later by the notion that the antenna, as constructed, somehow works very well so it must follow a particular theory of behavior of radio waves flowing on conductors of certain lengths.
I suspect that the design of the MORAD VHF-156 may have been developed in a similar manner as the 225-MHz sleeve dipole in the cited article. That is, the antenna was physically constructed and then many iterations of lengths and configurations were tested to arrive at the final configuration.
If there is any "secret sauce" in the MORAD VHF-156 antenna, it is probably occurring inside the tube section and at the point where the center conductor of the transmission line is tapped onto the radiating element. Unfortunately, no details are available of the exact configuration of that point inside the sleeve tube.
Re: MORAD VHF-156HD Antenna and Mounts
Postby jimh » Fri Aug 01, 2025 11:04 am
As a corollary project, I converted the wavelength dimensions from the 225-MHz monopole sleeve dipole to 156.8-MHz physical lengths:
Again, the highly developed 225-MHz antenna that had a great match to 50-Ohms used:
    upper radiator = 0.234 λ
    lower sleeve = 0.155 λ
Converting this to physical lengths at 156.8-MHz, I use a value for λ as 75.27-inches, which yields:
    upper radiator = 0.234 λ = 17.6-inches
    lower sleeve = 0.155 λ = 11.2-inches
Constructing a sleeve dipole with those dimensions should be an interesting project. There surely will need to be some length adjustments, as the diameters of the physical components at 156.8-MHz in terms of wavelengths will be smaller than those same physical sizes at 225-MHz were in the antenna developed by InConnection in their research.
In the article (linked above) the actual physical antenna was constructed with the radiator element made with 18-AWG solid copper wire. The sleeve element was made with copper pipe, but no dimension information was given. However, based on photographs, the sleeve was perhaps 0.5-inch OD or slightly larger.
The principal difference in this antenna from the MORAD is the feed point of the antenna is at the top of the sleeve element, and the vertical radiator terminates there.
On the MORAD antenna--and I do not know this for a fact--I believe the radiator rod continues downward inside the sleeve, and the feed point for the antenna is at the bottom or close to the bottom of the sleeve.
By employing a sleeve dipole design several benefits are said to exist:
  • the sensitivity of the antenna input impedance to frequency is said to decrease, giving wide VSWR bandwidths, and
  • the sleeve method provides an integrated way to tune the input impedance of the antenna to the desired value (50-Ohms usually).
In a sleeve dipole, the usually approach is changing the feed point to be off-center and varying the length of the sleeve. (Cf.: https://www.ece.mcmaster.ca/faculty/nikolova/antenna_dload/current_lectures/L11_Match.pdf }
Many standard reference antennas employ a sleeve dipole, which is thought to reduce change in antenna gain with change in frequency, making one physical antenna more useful over a wider range of frequencies with minimal gain variation.
