1998 Conquest 21 Known Defect
rathrBfishing
Postby rathrBfishing » Wed Apr 06, 2022 9:03 pm
I may buy a 1998 Conquest 21 with an Evinrude 175-HP engine.
What are known defects in a 1998 CONQUEST 21?
What are known defects in a Evinrude 175-HP engine?
Re: 1998 Conquest 21 Known Defects
Postby jimh » Wed Apr 06, 2022 11:43 pm
For advice on buying a used Boston Whaler boat, a used outboard engine, a used trailer, and various used accessories, see
https://continuouswave.com/whaler/reference/buying.html
NorthShoreWhaler
Postby NorthShoreWhaler » Fri Apr 08, 2022 10:20 am
Do research on the outboard engine.
Some early Evinrude FICHT engines had problems. They were first produced in 1997 I believe.
Postby Jefecinco » Fri Apr 08, 2022 10:47 am
If the engine is a FICHT and is in service after 24 years it was not one of those prone to problems and has likely had the upgrades recommended by Evinrude to improve reliability. The part on the FICHT engines most prone to early failure is the ECM which can fail if it becomes overheated. Many FICHT ECMs are water cooled. The cooling water passageways can become restricted by mud or other waterborne debris picked up in the cooling water system. Inspecting for the problem is relatively easy. The ECM can be removed and the passageways visually inspected. If there is any material it can be removed by careful cleaning with a pipe cleaner or similar item.
Before going to the effort to inspect the ECM I recommend you determine if it is water cooled.
Postby jimh » Fri Apr 08, 2022 1:04 pm
With no information provided about the engine other than horsepower and brand, it seems inappropriate to divert the discussion into the history of a particular model of Evinrude engine. If the OP needs good advice about the engine, the OP should give more information about the engine.
Re: 1998 Conquest 21 What To Look For
Postby jimh » Fri Apr 08, 2022 1:07 pm
Jefecinco wrote:If the engine is...in service after 24 years it was not one of those prone to problems ...
Very good point. Any engine still in working order 24-years after it was manufactured would seem to be an engine that so far has avoided catastrophic failure. That engine must not have any defects.
Predicting how much longer any 24-year-old engine will continue to operate normally will be quite speculative.
