1994 Outrage 17 Canvas
bobk
Postby bobk » Thu Oct 20, 2016 6:10 pm
I just picked up a clean [1994 Boston Whaler Outrage17] boat that had been stored out of the weather and seldom used. I want to keep the boat as fresh as possible and am looking for a good cover that will not be too difficult to get on and off. I also plan to put a Bimini top on it and will need the frame and fittings for it. The boat will continue to be lightly used and not stored in the water, but will be kept outside. I live in upstate New York, and the boat will mainly be used in fresh water. Price is a consideration but I understand that quality costs. Any suggestions would be appreciated. Thanks.
Re: 1994 Outrage17 new owner seeks cover and bimini advice
Postby Phil T » Thu Oct 20, 2016 6:44 pm
Bob--the Outrage 17 I (1990-1995) is a unique model and not many providers offer products that are a perfect fit.
Carver Industries makes a decent semi-fitted cover for the Outrage 17 .
http://dealerguide.carvercovers.com/boats/display/2124
For winter, I would do the sawhorses and heavy tarp technique due to snow load.
rzwhaler
Postby rzwhaler » Sun Oct 23, 2016 11:29 am
Check out Mills Canvas. They were the original supplier of canvas for that model and year. I own a 1994 21 Outrage. [Canvas from Mills can be] pricey, but [their work is] super quality. Their frames are the best. I then have canvas cut from their patterns
1994 21 ft Outrage
250 hp Yamaha Offshore
Southwest Florida Denizen
Re: 1994 Outrage 17 Canvas
Postby jimh » Sun Oct 23, 2016 12:46 pm
Canvas and frames from Wm. J. Mills & Co. are cut from patterns and you fit it to your boat when you install it. They use Glen Raven Mills SUNBRELLA fabric and stainless steel for their frames. Their workmanship is very good. If they offer pre-made canvas for your model of Boston Whaler boat, their prices can serve as a benchmark for the upper end of the market pricing.
Generally wherever there are lots of boats there is a local canvas maker. You can assess the quality of the local canvas maker by looking around at marinas in your area to see example of their work. If you see exemplary work, inquire with the local canvas maker and get his prices.
You can save money if you buy standard sized pre-made frames and canvas for a Bimini Top. As long as the width of the frame is properly selected, fitting a pre-made Bimini to your boat will not be too difficult.
Winter storage covers that are standard-size are very much cheaper than having a custom-made winter cover. The biggest worry I have about outdoor winter storage of boats is infestation of small rodents. If your boat becomes the winter home for some field mice you will regret letting them take up residence.
Postby jimh » Sun Oct 23, 2016 12:47 pm
rzwhaler wrote:Check out Mills Canvas. ...I then have canvas cut from their patterns
How did you get Wm. J. Mills & Co. to give you their patterns? I never heard of this before. Please elaborate.
rzwhaler
Postby rzwhaler » Sun Oct 23, 2016 7:37 pm
You either have the old canvas or buy new. You can take old canvas to any canvas shop and they make a pattern out of it. I never stated I got the patterns from them. any old canvas serves as a pattern
1994 21 ft Outrage
Postby jimh » Mon Oct 24, 2016 12:16 am
RZ'--Thanks for clarifying that you were not given patterns for canvas by Wm. J. Mills & Co. I cannot imagine that any canvas maker would give away their canvas patterns to someone so that person could then have another company make something from their patterns--and particularly not Mills who have an extensive collection of patterns for Boston Whaler boats.
RMS
Postby RMS » Mon Oct 24, 2016 9:31 am
I have a 1993 Outrage 17 and purchased a Mills mooring cover for summer use. Some price savings may be realized by purchasing the Mills cover through Twin Cities.
Bob
bobk
Postby bobk » Mon Oct 24, 2016 9:53 pm
Thank you all for responding. I've contacted Mills and will be ordering from them shortly.
