2005 170 Montauk: Same Size Replacement Cooler
boatsmith
Postby boatsmith » Fri Jan 13, 2017 10:20 am
I am looking for a new cooler for the front of the console for my 2005 17 0 Montauk. I would like to reuse the cushion and mounting brackets so I am looking for a same size replacement. The newer [Boston Whaler supplied coolers] have changed size. [Reply with your] thoughts [on a source for a same-size replacement cooler to fit the existing brackets and cushions for a 2005 170 MONTAUK]. Thanks
Re: 2005 170 Montauk: Same Size Replacement Cooler
Postby jimh » Fri Jan 13, 2017 10:47 am
Here are my thoughts:
In seeking a same-size replacement, you can probably find one in-stock at a Whaler dealer; check with TWIN CITIES MARINE, as they are very good replacement part sources, are known to be good to work with, and may have something.
Also, call Boston Whaler customer service and see what they have to say. They may tell you where to get the cooler from a retail outlet.
Finally, someone probably has figured this out; let's hope they chime in.
Postby Phil T » Fri Jan 13, 2017 12:35 pm
According to the Resources section of http://www.bostonwhaler.com/boat-ownership/resources/ the 2005 Montauk 170 came with a 72 qt cooler, the BW part # is 1691319.
According to the Resources section, the 2007 Montauk has the same size cooler with a different part #, 1016427
In later years, the Resources section does not include parts lists.
If you have the original cooler , take some measurements and compare to this:
https://www.igloocoolers.com/00044685-marine-ultra-72-white
If it is the same, shop around. Prices vary considerably, see http://continuouswave.com/forum/viewtopic.php?f=6&t=1758
Wweez
Postby Wweez » Mon Jan 16, 2017 12:34 pm
Replacements are higher quality igloo. 72 quart.
The whaler cushion is much better than the igloo cushion, so if you can use the existing one, you will save and be happier.
