Hello--I moved your thread to THE GAM, which is a forum that discusses general topics. I re-arranged your long post to make the questions being asked clearer. I deleted some of the lengthy comments you had that would not affect the answers to your questions. Here are some answers, which, due to the many questions, are brief but accurate replies:
Miquel wrote:Q1: is the difference in boat speed and fun factor between a SPORT 11 and a SPORT 13 great?
A1: the 13-foot hull has outsold the 11-foot hull by a huge ratio, maybe 500:1. I recommend you use that as an indicator of which one has the better fun factor.
Miquel wrote:Q2: what is the difference between a tender and dingy?
A2: a tender is a boat used to service a larger yacht. The 142-foot
BYSTANDER is a tender to the J-Class sailing yacht
VESHELDA. There is no size limit to a boat being a tender to a larger boat. A dingy is a very small boat, usually powered by oars, a small sail, or a very small outboard engine.
Miquel wrote:Q3: do various models of a 13-footer use the same hull?
A3: all classic era models noted as a 13-foot hull used the same hull. Later models noted as 13-foot boats tend to use different hulls. The specifications for hulls can be compared by reading:
Dimensions and Production Historyhttp://continuouswave.com/whaler/reference/specifications.htmlMiquel wrote:Q4: where can I learn how engine power affects performance of an outboard-engine-powered small skiff?
A4: boat speed for all hulls is related to total weight and propulsion power. For a moderate speed planing hull, boat speed varies with the power-to-weight ratio to the 0.5 exponent. Please see:
Propeller Basics: Part 2http://continuouswave.com/whaler/reference/prop2.htmlRead the section under the heading "CALCULATING SPEED POTENTIAL."
If you need a more in-depth explanation, purchase and read
The Propeller Handbookby Dave Gerr
Miquel wrote:Q5: is it permissible to post a link to craigslist and ask for an evaluation of the amount of repair necessary?
A5: Do not post links to temporary listing of boats for sale on other websites as the fundamental basis of a discussion. Notices of for-sale are generally very temporary and disappear in a matter of days. The value of a discussion about a boat that can no longer be seen then disappears with it. The website is not interested in collecting information whose value only lasts for a day or two.
For example, if you saw an advertisement for a particular Boston Whaler boat with a particular engine horsepower, and you want to know if the boat can reach plane, a good method is to look up the specification for minimum horsepower for that hull. Boston Whaler ratings for minimum horsepower are generally interpreted to mean the minimum horsepower to push the boat onto plane with the lightest load.
Miquel wrote:Q6: [inferred question] is the condition of a boat able to be judged from pictures?
A6: making a proper assessment of a boat's condition cannot be done only with pictures. An in-person inspection is necessary.
For advice on buying a classic era Boston Whaler boat, please see:
Buying Classic Boston Whaler Boatshttp://continuouswave.com/whaler/reference/buying.htmlTo get background on the 13-foot hull, please see:
The 13-foot Hullhttp://continuouswave.com/whaler/reference/13/To see answers to frequently asked questions about classic era Boston Whaler boats, please see:
Frequently Asked Questionshttp://continuouswave.com/whaler/reference/FAQ/The forum works best if each thread discusses one particular topic. Threads that ask many questions usually become difficult to follow because the replies to the initial post will branch in many different directions.
Welcome to the forum. If you need more advice about making a particular repair, use the REPAIRS and MODIFICATION forum for each particular repair. If you need more advice about the performance of a particular boat and engine combination, use the PERFORMANCE forum. Using the SEARCH function for the present forum can be helpful. You can also search the old forum and the entire website with the search method available in the old forum. See:
The Old Forumhttp://continuouswave.com/whaler/oldForum/
