Cberglund wrote:Will installing stern cleats be wrong?
I don't think there is any particular basis to make a judgement of right or wrong regarding adding cleats to the stern of a 13-footer. The only way I'd say adding cleats would be wrong is if the method used was awful and the results were hideous.
Cberglund wrote:Is installing stern cleats smart?
I don't think there is a basis to make a judgement of smart or dumb regarding adding cleats to the stern of a 13-footer. If there is presently no way to fasten a mooring line to your boat at the stern, then adding cleats sounds like a reasonable idea.
I added small stern cleats to my 1976 SPORT 15, mounting them on the inwale near the transom. I used them to attach a fender--there was no good place to attach a fender at the stern quarter--and for holding mooring lines for very short tie-ups in protected water. I didn't feel the cleats would be strong enough to hold mooring lines in a storm or rough seas. For strong mooring lines I used the stern towing-lifting eyes that are through-transom.
- Fig. 1. Cleats add to inwale of SPORT 15 near stern. They were intentionally NOT mounted
to the top of the gunwale so they would
not snag lines or interfere with stepping aboard. - sternCleatOnInwale.jpg (25.52 KiB) Viewed 3881 times
If you install cleats, they should be fastened into a part of the hull with embedded wood reinforcement. For my installation I was guided by the
wood locating diagram for my hull. You can find similar diagrams for the 13-foot hull in the
REFERENCE article for the 13-foot hull.
