2003 Outrage 21 or 2007 190 Montauk
boothm14
Postby boothm14 » Fri Feb 25, 2022 11:36 am
I live in New Jersey. I will use my boat for angling in Barnegat Bay. I won't go out farther than a few miles into the Atlantic Ocean.
Which boat would be better for me to buy:
  • a 2003 OUTRAGE 21 with 2003 Mercury 200-HP OptiMax, 1,000-hours, $25,000
  • a 2007 190 MONTAUK with 2019 Mercury ProXS 150, 50-hours, $30,000
Both boats have a trailer, and both boats appear to be in great shape.
ConB
Re: 2003 Outrage 21 or 2007 190 Montauk? HELP PLEASE
Postby ConB » Fri Feb 25, 2022 12:31 pm
The Montauk with the newer modern engine would be more attractive to me.
Con
1969 13 / 30hp Johnson tiller
macfam
Postby macfam » Sat Feb 26, 2022 6:51 am
I would go for the 190 Montauk [for the reasons mentioned above].
NorthShoreWhaler
Postby NorthShoreWhaler » Sat Feb 26, 2022 7:02 am
boothm14 wrote:Which boat would be better for me to buy
Montauk. Fifty hours is "brand new" on [an outboard engine].
Postby jimh » Sat Feb 26, 2022 7:30 am
Do not buy the boat with the OptiMax engine with 1,000-hours. That's too many engine hours, and I would avoid the OptiMax completely.
The Mercury OptiMax is a powerful engine, but it is a very complex design. Mercury dropped the OptiMax from its recreational outboard line in 2018, about four years ago. Mercury service shops that are expert on the OptiMax are hard to find, and this will only become more difficult going ahead.
Unless you are certain there is a very knowledeable Mercury local dealership with expert technicians for the OptiMax, I would not buy a 19-year-old OptiMax with 1,000-hours.
Postby Phil T » Sat Feb 26, 2022 9:49 pm
While I would select the Outrage 21, the motor included is a no-go.
The Montauk 190 with the Mercury FOURSTROKE engine is a great solution.
Postby Jefecinco » Sun Feb 27, 2022 10:16 am
We owned a 190 Montauk bought primarily for inshore and near offshore fishing. It excelled in both roles. The optional aft live bait well was a very useful option. We also added two rail mounted stainless steel clamp on rod holders to the side rails. The boat was powered with a 135 HP Verado engine which provided ample power. The included trailer was a Karavan galvanized single axle with disc brakes, it served us well including a tow from the point of purchase in St Louis, MO home to the Alabama Gulf Coast.
Postby jimh » Sun Feb 27, 2022 1:34 pm
The 190 MONTAUK dimensions are
BEAM = 8-feet 0-inches
LOA = 19-feet 4-inches
Compared to a classic OUTRAGE 18 later called OUTRAGE 19:
BEAM = 7-feet 2-inches
LOA = 18-feet 6-inches
Assuming both boats have a similar rounded bow, we can compare the area by just using the length and beam:
190 MONTAUK = 154-square-feet
OUTRAGE "19" = 132.5-square-feet
The 190 MONTAUK has 21.5-square-feet more area than the OUTRAGE "19", an increase of 16-percent. My point: the 190 MONTAUK is a big 19-footer.
