Retail Source for 1998 Outrage 20 Hatch Hinges
mpmegginson
Postby mpmegginson » Sun Apr 03, 2022 10:33 pm
Q1: Where can OEM hinges be purchased to replace the original hinges on a 1998 OUTRAGE 20 used on starboard aft compartment hatch cover just in front of transom?
Thanks for any help.
Re: Retail Source for 1998 OUTRAGE 20 Hatch Hinges
Postby Phil T » Mon Apr 04, 2022 8:19 am
Are you referring to the fishbox lid hinge, shown as item #2 on the diagram labeled "20’ Outrage Hull Assembly Sheet 3 and 4 1998" from the Resource Page on Boston Whaler's site?
A link to the PDF download is below.
https://www.bostonwhaler.com/content/dam/boston-whaler/technical/resources/200-Outrage-Hull-Assembly-Sheet-3-and-4-1998.pdf
The OEM hinge is from Perko. Check measurements on the boat and locate the hinge here:
https://www.perko.com/catalog/category_products/cabinet_hardware-hinges/
Screws and barrel nuts can be ordered from McMaster-Carr.
http://www.mcmaster.com
Re: Retail Source for 1998 Outrage 20 Hatch Hinges
Postby jimh » Mon Apr 04, 2022 9:37 am
Barrel Nuts are listed in the REFERENCE section for OEM Sources. See
https://continuouswave.com/whaler/refer ... barrelNuts
mpmegginson
Re: Retail Source for 1998 200 Outrage Hatch Hinges
Postby mpmegginson » Mon Apr 04, 2022 7:57 pm
It's actually item number 44 part number 1033232. Listed as 4 adjustable hinges. Chasing it down now. Still not sure where to find this. Perko didn't look like what I needed.
Postby Phil T » Tue Apr 05, 2022 10:08 am
I would describe that as the aft quarter seat base hinge.
Two parts guru's are at the Parts department of two respected Whaler dealers:
Sue Lodel, Twin Cities Marine
http://www.beacontcm.com
Jason/Justin, Nauset Marine
http://www.nausetmarine.com
Forward them the drawing info, part #, description.
mpmegginson
Postby mpmegginson » Tue Apr 05, 2022 10:23 pm
PHIL T--thank you.
mpmegginson
Postby mpmegginson » Thu Apr 28, 2022 10:24 am
Sue Lodel at Twin Cities Marine is the bomb. She knew exactly what I needed and got them in the mail the same day. Thank you Sue.
