Source for 8-foot Long Bimini Top
CasperD
Postby CasperD » Mon Apr 24, 2023 10:11 am
Where can an off-the-shelf 8-foot-long Bimini Top be purchased?
[Moderator's note: separated from another discussion and moved to THE GAM for comments.]
Re: Source for 8-foot-long Bimini Top
Postby jimh » Wed Apr 26, 2023 9:52 am
An eight-foot-long Bimini Top is available from many off-the-shelf sources. If you enter the search term "8-foot-long Bimini top" into a search engine like GOOGLE, you can find many vendors offering the required 8-foot-long Bimini top. Rather than repeat those search results here, you can just duplicate that search yourself.
In buying an off-the-shelf Bimini Top, the width of the top is very important, and this dimension must be selected to fit the particular boat on which you might be planning to install the top.
PhilD
Re: Source for 8-foot Long Bimini Top
Postby PhilD » Wed Apr 26, 2023 3:09 pm
I've bought a couple of bimini tops (including poles/hardware/etc) from Amazon and been pleasantly surprised at the quality for the price.
In addition to the width being within range, make sure you get the correct number of bows. You can also get support poles separately if the one you're looking at has straps on the ends.
Postby Phil T » Wed Apr 26, 2023 5:40 pm
Carver branded bimini's come in 8' lengths. Just add your height and width.
Offered by resellers. Here is one that many owners use:
https://www.boatcoversdirect.com/products/bimini_tops/by_dimensions/
