Gel Coat Color Use Reference from Boston Whaler
Postby jimh » Sun Dec 31, 2023 11:22 am
Boston Whaler has published a great resource for information about gel coat resin colors, the years the colors were used, and what Spectrum Gel Coat resin part number would be the equivalent.
The PDF document can be accessed at
https://www.bostonwhaler.com/resources- ... odes,-.pdf
I have also attached a copy of the document to this post. See below
GelCoatColorCodes.pdf
(218.41 KiB) Downloaded 861 times
For example, for my 1990 Boston Whaler REVENGE, the hull color was Desert Tan. For that particular year the Desert Tan factory color was used from 1972 through 1993, and the Spectrum equivalent would be #2203. In other years and ranges of years, a different Spectrum equivalent is specified.
The document also include paint colors for AWGRIP and IMRON finishes as used on more recently built hulls.
