DAUNTLESS 18 Remote Shift-Throttle Cable Length
DavesDauntless
Postby DavesDauntless » Thu May 30, 2024 6:31 am
[Inferred question:]
Q1: What is the length of the engine remote shift-throttle control cables on my 18 DAUNTLESS center console boat?
[Moderator's note: an old thread on a completely different topic that was dormant for about eight years was revived and the topic changed. Please do not revive threads that have been dormant for eight years. Please do not reply to any thread only to change the topic of the thread to something completely different. Please do not ask questions in the form of asking if any readers possess a certain knowledge.]
Re: DAUNTLESS 18 Remote Shift-Throttle Cable Length
Postby jimh » Thu May 30, 2024 11:13 am
DavesDauntless wrote:[Inferred question:]What is the length of the engine remote shift-throttle control cables on my 18 DAUNTLESS center console boat?
To give an appropriate response, please answer these questions:
Q2: do you have access to the boat?
Q3: are there engine remote control shift-throttle cables installed on this boat now?
Q4: If the answer to Q3 is yes, do you want to replace the existing cables with ones of the same length?
DavesDauntless
Postby DavesDauntless » Thu May 30, 2024 11:33 am
jimh wrote:Q2: do you have access to the boat?
Yes I have access [to the boat].
jimh wrote:Q3: are there engine remote control shift-throttle cables installed on this boat now?
Yes, [there are remote control shift-throttle cables] currently installed, [but the cables are] blown up with rust where accessible outside of the engine cowling.
jimh wrote:Q4: If the answer to Q3 is yes, do you want to replace the existing cables with ones of the same length?
Yes. I want to change to [new cables of] the same length.
ASIDE
My apologies as I am a first-time user and I just closed on the boat.
Postby jimh » Sat Jun 15, 2024 8:34 am
Since you have access to the boat, there are already remote throttle-shift cables installed, and you want the replacement cables to be the same length, then:
Q5: why can't you just measure the length of the existing remote shift-throttle cables to discover their length?
DavesDauntless
Postby DavesDauntless » Mon Jun 17, 2024 7:33 am
I had hoped to pre-buy the cables and pull them through the [rigging tunnel path] with the old cables.
I ended up running a line [that followed the rigging tunnel path of the existing cables], from which I found that the cable length was 18-feet.
Moderator's note: on a center console boat build by Boston Whaler, there is usually a rigging path provided between the helm console and the engine splash well area that is concealed below the deck. This path is generally known as a "rigging tunnel" although is some instances it is not a completely enclosed tunnel but is a molded trench in the hull liner that is then covered by a section of the cockpit deck that may be able to be removed. The illustration below shows a typical arrangement for a rigging tunnel as seen when the deck cover has been removed:
FI. 1. View of the rigging tunnel (left side) (or more appropriately a rigging trench) when the cockpit deck cover is removed, as seen on an OUTRAGE 18 model. Photo credit: Jeff Rohlfing.
Don SSDD
Postby Don SSDD » Sat Jun 22, 2024 10:04 am
These cables typically may have a part number or maybe a coding in the part number which tells you the length presently installed. On an older boat the sun may have removed the part number so look where the sun doesn’t shine, inside the console, if not visible elsewhere.
If your steering cable is sticking, that may be caused by the outboard pivot tube having rusted inside where the steering cable passes through, there may be nothing wrong with your cable. Or maybe you are just doing preventative maintenance ?
Nova Scotia
