Q1: what is the hull weight of a c.1960 KATAMA 16?
Q2: what is the official height from the keel to the top of the center console of a c.1960 KATAMA 16?
When directed to the reference page for the 16/17 hull I see two weights: 550-lbs and 850-lbs.
I plan to move the boat on a trailer, so knowing the actual weight is important to me.
I plan store the boat in a garage, so knowing how high the boat will sit on a trailer is important to me.
c.1960 KATAMA Specifications
Re: c.1960 KATAMA Specifications
The REFERENCE article on the 16/17 hull lists four different weights. Each weight is for a different model and different production era. There is no weight listed for a c.1960 KATAMA 16. The KATAMA production began in 1969.lambandbert wrote:When directed to the reference page for the 16/17 hull I see two weights: 550-lbs and 850-lbs.
Hull weights are known to vary. If you believe that you need to know the precise hull weight of your particular hull in order to select the proper trailer, you should weigh the actual hull you have. An early model KATAMA from c.1969 could be about 55-years old, and its hull weight could be far from the original weight when it left the factory due to some accumulation of water in the foam interior of the Unibond hull. Also, the typical rigging of an engine, a fuel tank, and other items normally on a boat (anchor, lines, fenders, cooler, and so on) will all affect the total boat weight when on a trailer.lambandbert wrote:I plan to move the boat on a trailer, so knowing the actual weight is important to me.
If you are concerned about the height in order to fit into a garage you will need to measure to the top of the railing that holds the canvas windshield and the shepherd's crook railing, not just to the top of the console. The rigging of the boat on a particular trailer will also affect how much vertical clearance will be needed to fit in garage. Tire size for the trailer is also an influence on height.
